Following the DQN algorithm with experience replay:
Store transition $\left(\phi_{t}, a_{t}, r_{t}, \phi_{t+1}\right)$ in $D$ Sample random minibatch of transitions $\left(\phi_{j}, a_{j}, r_{j}, \phi_{j+1}\right)$ from $D$ Set
$$y_{j}=\left\{\begin{array}{cc}r_{j} & \text { if episode terminates at j+1} \\ r_{j}+\gamma \max _{d^{\prime}} \hat{Q}\left(\phi_{j+1}, a^{\prime} ; \theta^{-}\right) & \text {otherwise }\end{array}\right.$$
Perform a gradient descent step on $\left(y_{j}-Q\left(\phi, a_{j} ; \theta\right)\right)^{2}$ with respect to the network parameters $\theta$.
We calculate the $loss=(Q(s,a)-(r+Q(s+1,a)))^2$.
Assume I have positive but changing rewards. Meaning, $r>0$.
Thus, since the rewards are positive, by calculating the loss, I notice that almost always $Q(s)< Q(s+1)+r$.
Therefore, the network learns to always increase the $Q$ function , and eventually, the $Q$ function is higher in same states in later learning steps.
How can I stabilize the learning process?
Faizy
  • 1,144
  • 30
BestR
  • 183
  1. You can use discount factor gamma less then one.
  2. You can use finite time horizon - only for states which are no farther away then T time steps reward propagate back
  3. You can use sum of rewords averaged over time for Q
All of those are legitimate approaches.
mirror2image
  • 735
  • 15
Therefore,the network learns to always increase the Q function , and eventually the Q function is higher in same states in later learning steps
If your value function keeps increasing in later steps that means that the network is still learning those Q-values, you shouldn't necessarily prevent that. Your Q-values won't increase forever even if the rewards are always positive. You basically have a regression problem here and when the value of $Q(s,a)$ becomes very close to the predicted value of $r+Q(s',a)$ value of $Q(s,a)$ will stop increasing by itself.
Brale
  • 2,416
  • 15
I changed the rewards to be negative and positive by substructing the mean reward.
It seems to improve the Q function boundries.
BestR
  • 183
The popular Q-learning algorithm is known to overestimate action values under certain conditions. It was not previously known whether, in practice, such overestimations are common, whether they harm performance, and whether they can generally be prevented. In this paper, we answer all these questions affirmatively. In particular, we first show that the recent DQN algorithm, which combines Q-learning with a deep neural network, suffers from substantial overestimations in some games in the Atari 2600 domain. We then show that the idea behind the Double Q-learning algorithm, which was introduced in a tabular setting, can be generalized to work with large-scale function approximation. We propose a specific adaptation to the DQN algorithm and show that the resulting algorithm not only reduces the observed overestimations, as hypothesized, but that this also leads to much better performance on several games. https://www.aaai.org/ocs/index.php/AAAI/AAAI16/paper/viewPaper/12389
taarraas
  • 101
