The $\lambda$-return is defined as $$G_t^\lambda = (1-\lambda)\sum_{n=1}^\infty \lambda^{n-1}G_{t:t+n}$$ where $$G_{t:t+n} = R_{t+1}+\gamma R_{t+2}+\dots +\gamma^{n-1}R_{t+n} + \gamma^n\hat{v}(S_{t+n})$$ is the $n$-step return from time $t$.
How can we use this definition to rewrite $G_t^\lambda$ recursively?
Philip Raeisghasem
  • 2,074
  • 30
To rewrite $G_t^\lambda$ recursively, our goal is to define it in terms of $$G_{t+1}^\lambda = (1-\lambda)\sum_{n=1}^\infty \lambda^{n-1}G_{t+1:t+n+1}.\tag{0}$$
The $\lambda$-return is a weighted average of all $n$-step returns. We will split up the summation by pulling out the one-step return $G_{t:t+1}$ and the first step's reward $R_{t+1}$.
$$ \begin{align*} G_t^\lambda &= (1-\lambda)\sum_{n=1}^\infty \lambda^{n-1}G_{t:t+n} \tag{1}\\ &\\ &= (1-\lambda)\lambda^0G_{t:t+1} + (1-\lambda)\sum_{n=2}^\infty \lambda^{n-1}G_{t:t+n}\tag{2}\\ &\\ &= (1-\lambda)\left(R_{t+1}+\gamma\hat{v}(S_{t+1})\right)\\ &\qquad + (1-\lambda)\sum_{n=2}^\infty \lambda^{n-1}(R_{t+1}+\gamma R_{t+2}+\dots +\gamma^{n-1}R_{t+n} + \gamma^n\hat{v}(S_{t+n}))\tag{3}\\ &\\ &= (1-\lambda)\left(R_{t+1}+\gamma\hat{v}(S_{t+1})\right) + (1-\lambda)\sum_{n=2}^\infty \lambda^{n-1} R_{t+1}\\ &\qquad + (1-\lambda)\sum_{n=2}^\infty \lambda^{n-1}(\gamma R_{t+2}+\dots +\gamma^{n-1}R_{t+n} + \gamma^n\hat{v}(S_{t+n}))\tag{4}\\ &\\ &= \gamma(1-\lambda)\hat{v}(S_{t+1}) + (1-\lambda)\sum_{n=1}^\infty \lambda^{n-1} R_{t+1}\\ &\qquad + (1-\lambda)\sum_{n=2}^\infty \lambda^{n-1}(\gamma R_{t+2}+\dots +\gamma^{n-1}R_{t+n} + \gamma^n\hat{v}(S_{t+n}))\tag{5}\\ &\\ &= \gamma(1-\lambda)\hat{v}(S_{t+1}) + R_{t+1}\\ &\qquad + (1-\lambda)\sum_{n=2}^\infty \lambda^{n-1}(\gamma R_{t+2}+\dots +\gamma^{n-1}R_{t+n} + \gamma^n\hat{v}(S_{t+n}))\tag{6}\\ &\\ &= \gamma(1-\lambda)\hat{v}(S_{t+1}) + R_{t+1}\\ &\qquad + \gamma\lambda(1-\lambda)\sum_{n=2}^\infty \lambda^{n-2}(R_{t+2}+\dots +\gamma^{n-2}R_{t+n} + \gamma^{n-1}\hat{v}(S_{t+n}))\tag{7}\\ &\\ &= \gamma(1-\lambda)\hat{v}(S_{t+1}) + R_{t+1}\\ &\qquad + \gamma\lambda(1-\lambda)\sum_{m=1}^\infty \lambda^{m-1}(R_{t+2}+\dots +\gamma^{m-1}R_{t+m+1} + \gamma^{m}\hat{v}(S_{t+m+1}))\tag{8}\\ &\\ &= \gamma(1-\lambda)\hat{v}(S_{t+1}) + R_{t+1} + \gamma\lambda(1-\lambda)\sum_{m=1}^\infty \lambda^{m-1}G_{t+1:t+m+1}\tag{9}\\ &\\ &= \gamma(1-\lambda)\hat{v}(S_{t+1}) + R_{t+1} + \gamma\lambda G_{t+1}^\lambda \tag{10}\\ \end{align*} $$
$(2)$ pulls out the one-step return from the summation.
$(3)$ expands the $n$-step returns.
$(4)$ pulls out the remaining first step rewards.
$(5)$ combines first step rewards.
$(6)$ simplifies the geometric series.
$(7)$ pulls a factor of $\gamma\lambda$ out of the summation.
$(8)$ makes the substitution $m=n-1$.
$(9)$ uses the definition of the $n$-step return.
$(10)$ uses the definition of the $\lambda$-return
The result can be verified in equation $(12.18)$ of Sutton and Barto's RL book.
Philip Raeisghasem
  • 2,074
  • 30
