I was given the following problem to solve.
Given a circular trail divided by $n> 2$ segments labeled $0 \dots n-1$. In the beginning, an agent is at the start of segment number $0$ (the edge between segments $n-1$ and $0$) and the agent's speed ($M$) is $0$ segments per minute.
At the start of each minute the agent take one of three actions:
  • speed up: the agent's speed increases by $1$ segment per minute.
  • slow down: the agent's speed decreases by $1$ segment per minute.
  • keep the same speed: stay at the same speed.
The action slow down cannot be used if the current speed is $0$ segments per minute.
The cost of each action is $1$.
The goal of the agent is to drive around the trail k times ($1 \leq k$) and then park in the beginning spot (at speed 0 of course). The agent needs to do that in the minimum amount of actions.
The heuristic given is: If agent is in segment $z$ then: $n-z$ if $z \not = 0$ or $0$ if $z=0$.
I need to find if the given heuristic is admissible (or complete) and consistent.
I think:
  • Regarding consistency: A heuristic is consistent if its estimate is always $\leq$ estimated distance from any given neighbour vertex to goal plus cost of reaching a goal. So, in the given problem, it is consistent because ($n>2$), so heuristic function is well defined and because of circular trail divided by $n$ segments with a constant price of $1$ for each action, then the given definition of consistency holds because estimated distance from any given neighbour vertex to goal can be looked on as a difference between segments until reaching a goal and it is consistent because again the function is well defined.
  • Regarding admissibility: An admissible heuristic is one that the cost to reach goal is never more than the lowest possible cost from the current point to reach the goal. I am not sure if the given heuristic is admissible because it does not help much to know the difference between trail size ($n$ = segment size) and current place. But it does not create flaws, so it is probably admissible. I am not sure this is a proof.
Is my idea correct? How could I write it as a proof?
nbro
  • 42,615
  • 119
  • 217
hpr16
  • 41
Welcome to AI.SE @hpr16!
Your understanding of when a heuristic is admissible is correct, but your heuristic is inadmissible. An admissible heuristic must always underestimate the cost to move from a given state to a goal state.
Notice that states in the search are not the same as positions on the circle in your problem. A state needs to capture all the information about the current environment the agent is in. In your problem, agents have a speed as well as a position. A state must, therefore, contain both.
To see why your heuristic is inadmissible because the agent can move (n-z) segments in less than n-z steps: it can speed up, and do them in, for example, (n-z)/2 steps, by moving with speed 2.
John Doucette
  • 9,452
  • 19
  • 52
