106
Dimensional analysis, and the notion that quantities with different units cannot be equal, is often used to justify very specific arguments, for example, you might use it to argue that a particular formula cannot possibly be the correct expression for a particular quantity. The usual approach to teaching this is to go "well kids, you can't add apples and oranges!" and then assume that the student will just find it obvious that you can't add meters and seconds.
I'm sorry, but... I don't. I'm not convinced. $5$ meters plus $10$ seconds is $15$! Screw your rules! What are the units? I don't know, I actually don't understand what that question means.
I'm specifically not convinced when this sort of thing is used to prove that certain formulae can't possibly be right. Maybe the speed of a comet is given by its period multiplied by its mass. Why not? It's a perfectly meaningful operation - just measure the quantities, multiply them, and I claim that the number you get will always equal the current speed of the comet. I don't see how "but it doesn't make sense to say mass times time is equal to distance divided by time" can be a valid counterargument, particularly because I don't really know what "mass times time" is, but that's a different issue.
If it's relevant, I'm a math student and know extremely little about physics.
Jack M
  • 2,079
11 Answers11
136
Physics is independent of our choice of units
And for something like a length plus a time, there is no way to uniquely specify a result that does not depend on the units you choose for the length or for the time.
Any measurable quantity belongs to some set $\mathcal{M}$. Often, this measurable quantity comes with some notion of "addition" or "concatenation". For example, the length of a rod $L \in \mathcal{L}$ is a measurable quantity. You can define an addition operation $+$ on $\mathcal{L}$ by saying that $L_1 + L_2$ is the length of the rod formed by sticking rods 1 and 2 end-to-end.
The fact that we attach a real number to it means that we have an isomorphism $$ u_{\mathcal{M}} \colon \mathcal{M} \to \mathbb{R}, $$ in which $$ u_{\mathcal{M}}(L_1 + L_2) = u_{\mathcal{M}}(L_1) + u_{\mathcal{M}}(L_2). $$ A choice of units is essentially a choice of this isomorphism. Recall that an isomorphism is invertible, so for any real number $x$ you have a possible measurement $u_{\mathcal{M}}^{-1}(x)$. I'm being fuzzy about whether $\mathbb{R}$ is the set of real numbers or just the positive numbers; i.e. whether these are groups, monoids, or something else. I don't think it matters a lot for this post and, more importantly, I haven't figured it all out.
Now, since physics should be independent of our choice of units, it should be independent of the particular isomorphisms $u_Q$, $u_R$, $u_S$, etc. that we use for our measurables $Q$, $R$, $S$, etc. A change of units is an automorphism of the real numbers; given two units $u_Q$ and $u'_Q$, the change of units is $$ \omega_{u,u'} \equiv u'_Q \circ u_Q^{-1}$$ or, equivalently, $$ \omega_{u,u'} \colon \mathbb{R} \to \mathbb{R} \ni \omega(x) = u'_Q(u_Q^{-1}(x)). $$ Therefore, \begin{align} \omega(x+y) &= u'_Q(u_Q^{-1}(x+y)) \\ &= u'_Q(u_Q^{-1}(x)+u_Q^{-1}(y)) \\ &= u'_Q(u_Q^{-1}(x)) + u'_Q(u_Q^{-1}(y)) \\ &= \omega(x) + \omega(y). \end{align}
So, since $\omega$ is an automorphism of the reals, it must be a rescaling $\omega(x) = \lambda x$ with some relative scale $\lambda$ (As pointed out by @SeleneRoutley, this requires the weak assumption that $\omega$ is a continuous function -- there are everywhere discontinuous solutions as well. Obviously units aren't useful if they are everywhere discontinuous; in particular, so that instrumental measurement error maps an allowed space of $u_\mathcal{M}$ into an interval of $\mathbb{R}$. If we allow the existence of an order operation on $\mathcal{M}$, or perhaps a unit-independent topology, this could be made more precise.).
Consider a typical physical formula, e.g., $$ F \colon Q \times R \to S \ni F(q,r) = s, $$ where $Q$, $R$, and $S$ are all additive measurable in the sense defined above. Give all three of these measurables units. Then there is a function $$ f \colon \mathbb{R} \times \mathbb{R} \to \mathbb{R} $$ defined by $$ f(x,y) = u_S(F(u_Q^{-1}(x),u_R^{-1}(y)). $$
The requirement that physics must be independent of units means that if the units for $Q$ and $R$ are scaled by some amounts $\lambda_Q$ and $\lambda_R$, then there must be a rescaling of $S$, $\lambda_S$, such that
$$ f(\lambda_Q x, \lambda_R y) = \lambda_S f(x,y). $$
For example, imagine the momentum function taking a mass $m \in M$ and a velocity $v \in V$ to give a momentum $p \in P$. Choosing $\text{kg}$ for mass, $\text{m/s}$ for velocity, and $\text{kg}\,\text{m/s}$ for momentum, this equation is $$ p(m,v) = m*v. $$ Now, if the mass unit is changed to $\text{g}$, it is scaled by $1000$, and if the velocity is changed to $\text{cm/s}$, it is scaled by $100$. Unit dependence requires that there be a rescaling of momentum such that $$ p(1000m,100v) = \lambda p(m,v). $$ This is simple -- $10^5 mv = \lambda mv$ and so $\lambda = 10^5$. In other words, $$ p[\text{g} \, \text{cm/s}] = 10^5 p[\text{kg} \, \text{m/s}]. $$
Now, let's consider a hypothetical situation where we have a quantity called "length plus time", defined that when length is measured in meters and time in seconds, and "length plus time" in some hypothetical unit called "meter+second", the equation for "length plus time" is $$ f(l,t) = l + t. $$ This is what you've said - $10 \text{ m} + 5 \text{ s} = 15 \text{ “m+s”}$. Now, is this equation invariant under a change of units? Change the length scale by $\lambda_L$ and the time scale by $\lambda_T$. Is there a number $\Lambda$ such that $$ f(\lambda_L l, \lambda_T t) = \lambda_L l + \lambda_T t $$ is equal to $$ \Lambda f(l,t) = \Lambda(l+t) $$ for all lengths and times $l$ and $t$? No! Therefore, this equation $f = l + t$ cannot be a valid representation in real numbers of a physical formula.
jwimberley
  • 3,911
38
All right, I'm cashing in my comments to provide an answer:
Let's start with an example that doesn't invoke dimensions, units, or physics at all. How do we evaulate the following expression? $$ 1 + \begin{pmatrix}5\\2\\-9\end{pmatrix} + \begin{pmatrix}a\ b\\c\ d\end{pmatrix} $$
The answer is, we don't. Not without defining some special convention, like that every quantity is multiplied by some invisible matrix such that they all end up being $3\times3$ matrices... that's just arbitrary, and inconsistent.
Now, how do we interpret $5 \text{meter} + 10 \text{seconds}$? The answer is, we don't. Again, not without defining some arbitrary, inconsistent, and meaningless convention. You proposed it's equal to 15; well I will define $5\text{m}+10\mu \text{s}=15$ as well, and now we've just proven that microseconds equal seconds.
The lesson is, there's not a meaningful way to perform addition on disparate types of quantities. In physics, we refer to the general types as dimensions. Examples of dimensions are: length, time, energy, mass, etc. Units are specific ways to represent dimensions, for example meters and feet are both units of dimension length.
So, how does this relate to your comet example? You've observed (correctly) that we can in fact multiply different dimensions. E.g. mass times velocity has dimensions of momentum. But that still doesn't mean you can compare disparate quantities. The condition for your calculation to be correct is: $$ (\text{comet mass})\times(\text{period}) - (\text{the true speed}) = 0 $$ But as we've already shown, this expression is meaningless since we cannot add (or subtract) quantities of differing dimensions.
chase
  • 1,383
37
In physics, you're not allowed to ignore the units; they come along for the ride on every sub-step of every calculation. From a mathematics perspective, consider the units to be variables, so instead of 5 meters + 10 seconds, you have 5x + 10y. Unless you arbitrarily assign x = y = 1, there is no way you're getting 15 out of this; at the end of the day, you still have 5x + 10y, and physics is uninterested in complex numbers. At the end of a computation, you need one number, and "5x + 10y" is two numbers. And here's the rub in physics: you're not allowed to assign values to those variables. They are basic, irreducable units; you can't say "meters are 1".
On the other hand, you're allowed to multiply units like nobody's business. "Furlongs per fortnight" is a silly phrase, but you can use it and everyone will (after some conversion) understand exactly what you're saying:
$$13440\frac{\text{furlongs}}{\text{fortnight}} \times \frac{1 \; \text{mile}}{8 \; \text{furlongs}} = 1680\frac{\text{miles}}{\text{fortnight}}$$
$$1680 \frac{\text{miles}}{\text{fortnight}} \times \frac{1 \; \text{fortnight}}{336 \; \text{hours}} = 5 \frac{\text{miles}}{\text{hour}}$$
(Cue a horde of angry physicists descending upon me for my use of Imperial units.)
On every step of these conversions, the units never went away; they stayed with the numbers. When you're computing something in physics, the numbers you play with are real things; they represent a quantity of something, and that something doesn't go away just because you think it's inconvenient. So if an asteroid goes 10 meters in 5 seconds, it looks like this:
$$10 \; \text{meters} \times \frac{1}{5 \; \text{seconds}} = 2 \frac{\text{meters}}{\text{second}}$$
You can multiply and divide quantities however you like, and you'll end up with some funky units, but your final number will be valid — though they may be difficult to relate to everything else. (For instance, the viscosity of a fluid is measured in (kilograms per (meter * second)), which isn't particularly intuitive but is useful in the particular places that viscosity is used.)
Hunter
  • 5,328
36
Most of the answers seem to be reiterating that you're not allowed to add lengths and times just because it doesn't make sense. Here's why it doesn't make sense.
If two objects have the same temperature in Celsius, then they have the same temperature in Fahrenheit.
If two objects have the same speed in meters per second, then they have the same speed in miles per hour.
But if two objects have the same "length-time sum" in meters + seconds, they may not have the same "length-time sum" in other units. For example, $$60\,\text{meters}+0\,\text{seconds}\ “=”\ 0\,\text{meters}+60\,\text{seconds}$$ but $$60\,\text{meters}+0\,\text{minutes}\ “\ne”\ 0\,\text{meters}+1\,\text{minute}.$$ So it doesn't make sense to think of the length-time sum as a real physical quantity instead of a numerical coincidence caused by our choice of units.
This is basically the last part of jwimberley's answer, but I thought it would be helpful to have an explicit example spelled out so that the point is blindingly obvious.
bdesham
  • 319
22
Jack, I will explain the problem here first in a mathematical rather than physical way. The mathematical issue at play here is that the operation you are proposing is not well-defined at the level of basic physics. Let's take a look at some situations in math where this type of problem crops up that have nothing to do with physical units.
In calculus, we have $\int_a^b f(x)\,dx = F(b) - F(a)$ where $F(x)$ is any antiderivative of $f(x)$. What if someone came along and asked if a new operation $I(f,a,b) = F(b) + F(a)$ has any useful meaning in terms of the original function $f(x)$ and interval $[a,b]$. It does not, because if you change the antiderivative you change the answer. For any two antiderivatives $F(x)$ and $G(x)$ of $f(x)$, they differ by a constant, say $G(x) = F(x) + C$. This means that a difference of antiderivatives of $f(x)$ at $a$ and $b$ is independent of the choice of antiderivatives but a sum of antiderivatives of $f(x)$ at $a$ and $b$ is not: $$ G(b) - G(a) = (F(b) + C) - (F(a) + C) = F(b) - F(a) $$ while $$ G(b) + G(a) = (F(b) + C) + (F(b) + C) = F(b) + F(a) + 2C, $$ which is not $F(b) + F(a)$ unless $C = 0$ (i.e., $G(x) = F(x)$). So a difference of values of an antiderivative of $f(x)$ is a well-defined number in terms of the original function $f(x)$, but a sum of values of an antiderivative is not. If you want to provide a definite real number from an antiderivative of $f(x)$, and have that definite number be determined solely by $f(x)$ and not the choice of antiderivarive, differences make sense but sums do not. By the way, this has a role in physics: potential energy is only defined up to an overal additive constant, which explains why a difference of potential energy values has a physical meaning but a sum of potential energy values does not.
Another example is in geometry. We add angles but we don't ever multiply angles. Is there a mathematical problem with multiplying angles? Yes: angle measurement is intrinsically only determined up to an integer multiple of $2\pi$, and this property is respected by addition but not by multiplication. If $\theta_2 = \theta_1 + 2\pi{k}$ and $\varphi_2 = \varphi_1 + 2\pi{\ell}$ for some integers $k$ and $\ell$, then $$ \theta_2 + \varphi_2 = \theta_1 + \varphi_1 + 2\pi(k+\ell), $$ so the two sums $\theta_2 + \varphi_2$ and $\theta_1 + \varphi_1$ are again equal up to an integer multiple of $2\pi$. However, $$ \theta_2\varphi_2 = \theta_1\varphi_1 + 2\pi(k\varphi_1 + \ell\theta_1 + 2\pi{k}\ell) $$ and $k\varphi_1 + \ell\theta_1 + 2\pi{k}\ell$ is not an integer all the time. (If you have had abstract algebra, I could say the "problem" here is that $2\pi{\mathbf Z}$ is a subgroup of ${\mathbf R}$ but not an ideal in ${\mathbf R}$, so the quotient ${\mathbf R}/2\pi{\mathbf Z}$ can be given the structure of an additive group but not a ring.) If you want to say "but I can talk about $\sin(xy)$ for any numbers $x$ and $y$, and that is multiplying angles", I'd say it is not: in the expression $\sin(xy)$ with real variables $x$ and $y$, the numbers $x$ and $y$ must be regarded as real numbers, not angles. The story is different with $\sin(2x)$, which is well-defined when $x$ is thought of as an angle (a number up to addition by an integral multiple of $2\pi$). This distinction is why the $x$ in a Fourier series $$ f(x) = \sum_{n \in {\mathbf Z}} c_ne^{2\pi{i}nx} $$ can be thought of as lying on a circle if you wish, but the $x$ in a Fourier transform $$ ({\mathcal F}f)(x) = \int_{{\mathbf R}} f(y)e^{2\pi{i}xy}\,dy $$ can not and must be thought of on the real line: the Fourier transform is not a $2\pi$-periodic function of $x$, so it is not well-defined to regard the Fourier transform as a function on the unit circle.
In linear algebra, the trace of a linear operator $A \colon V \rightarrow V$ on a finite-dimensional vector space is defined to be $\sum_{i} a_{ii}$ where $(a_{ij})$ is a matrix representation of $A$ in a basis of $V$. It is crucial that that this sum is independent of the choice of basis. We used a basis to compute the trace, but if you want the trace to be a function purely of the operator $A$ then it has to have the same value no matter what basis you use on $V$. In a linear algebra course you learn that the trace is independent of the basis used to compute it. On the other hand, the "anti-trace" $\sum_{i} a_{i,n+1-i}$ (sum on the antidiagonal) or "border trace" (sum around the boundary of a matrix representation of $A$) are not well-defined because if you change the basis then the new matrix representation has a different value for its anti-trace or border trace. That's why you never hear anyone talk about such sums in linear algebra, since they are not well-defined functions of the original operator: they depend on the choice of basis. To the extent you agree that geometric concepts should not depend on your choice of coordinate system, you'll agree that useful concepts in linear algebra should be independent of the choice of basis.
In algebraic geometry, polynomials are not well-defined functions on projective space since their values change if the homogeneous coordinates change. But ratios of homogeneous polynomials of the same degree do give the same answer for all homogeneous coordinates of a point, and that is why ratios of homogeneous polynomials of the same degree are the natural functions on projective space.
In grade school math, addition of fractions is not $(a/b) + (c/d) = (a+c)/(b+d)$, since this operation is not well-defined: although 1/2 = 5/10 and 3/4 = 6/8, this fake way of combining fractions by adding numerators and denominators doesn't lead to the same answer when you change the way you write the fraction: $(1+3)/(2+4) = 4/6$ and $(5+6)/(10+8) = 11/18 \not= 4/6$. If you were to fix a preferred representation of fractions, such as the representation using relatively prime numerator and denominator with a positive denominator, then this "add the numerators and add the denominators" is a well-defined operation, but it would be very awkward to use because it would depend on the way you write the fractions. This fake addition does have an interesting application, which you'll learn if you read about Farey fractions; it just doesn't correspond to addition, so we shouldn't denote it as +, and it does not generalize to fractions where the numerator and denominator are in a ring that lacks unique factorization (and a preferred choice of unit multiple of each nonzero element).
If you don't think having operations be well-defined is important in math then you're going to be in for a mountain of trouble when you learn algebra (quotient groups) or differential geometry (manifolds), where you regularly have to define functions by making a choice and then check the answer is independent of the choice that was made (a choice could mean a coset representative or a choice of coordinate system near a point).
And if you don't think issues of "units" occur in math, you're mistaken. They are just hidden enough that you may not notice them. To measure angles we prefer to use radians. If you wanted to use other systems of measuring angles then the familiar derivative formulas for trigonometric functions would change: while $\sin'(x) = \cos(x)$ when $x$ is an angle in radians, if you change $x$ to degrees then $\sin'(x) = (\pi/180)\cos(x)$. We prefer radians because they lead to the simplest calculus formulas, without any weird factors like $\pi/180$ showing up. In Fourier analysis, some prefer to define the Fourier transform using $e^{ixy}$ instead of $e^{2\pi{i}xy}$, and then factors of $2\pi$ or $\sqrt{2\pi}$ start showing up in other formulas from Fourier analysis such as Parseval's formula. In linear algebra, we prefer to take as the "natural" isomorphism from a finite-dimensional vector space $V$ to its double dual space the mapping $v \mapsto {\rm ev}_v$, where ${\rm ev}_v(\varphi) = \varphi(v)$ for all linear functionals $\varphi$ on $V$, but there are other possibilities, namely $v \mapsto c\cdot{\rm ev}_v$ for any nonzero element $c$ of the underlying scalar field. Category-theoretic arguments show that these are essentially the only possible natural isomorphisms to the double-dual space.
Now I'll turn to physical measurements. If you want to add a length and a time together, you need to recognize that there is no natural standard for measuring either of these quantities: any two systems of measuring length differ by a scaling factor, and any two systems of measuring time differ by a scaling factor. Even if everyone on our planet used the metric system, it doesn't make that system physically profound. At some point in the past someone picked a length and declared it one meter, but that human convention doesn't have any physical importance. (If you think metric units are actually an essential part of the fabric of nature, then something has gone badly wrong in your education. Maybe the "radius of the electron" or the Planck length could be considered a physically fundamental length, but your question is on a much more elementary level than that.) The link between different measurements of the same physical quantity is not always just a scaling factor (temperature is the best example of that, where $F = (9/5)C + 32$), but for simplicity let's stick to conversions between different systems of measurement as being just scaling factors.
Because of the physical "fact" that different systems of measuring the same physical concept differ by a scaling factor, a physical measurement can be thought of as a real-valued function defined up to an overall positive scaling factor. If $f$ and $g$ are two ways of measuring the same physical quantity, then $g = cf$ for some positive $c$. For instance, if we are measuring length ($L$) and write $f_L$ for the meter-function and $g_L$ for the feet-function, then $c = 3.28$: $g_L(x) = 3.28f_L(x)$ (that is, to convert from meters to feet, multiply the meters value by 3.28). If we are measuring time ($T$), with $f_T$ for the second-function and $g_T$ for the minute-function, then $c = .016$: $g_T(y) = .016f_T(y)$ (to convert from seconds to minutes, multiply the second value by .016). Now ask yourself: if a function is defined up to an overall scaling factor, and another function is defined up to an overall scaling factor, what can I do with them and keep the result defined up to an overall scaling factor? You can multiply them or divide them, but you can't add them.
For example, if $g_L = 3.28f_L$ and $g_T = .016f_T$, then $g_L/g_T = 205f_L/f_T$. Recalling what these functions meant above, this last equation says if you want to convert from meters per second to feet per minute, multiply by 205. And $g_Lg_T = .05248f_Lf_T$, so to convert from meters-seconds (whatever that means) to feet-minutes, multiply by .05248.
Let's finally try addition: if $g_L = 3.28f_L$ and $g_T = .016f_T$, is $g_L + g_T = c(f_L+f_T)$ for some $c > 0$? This is the test for whether addition of measurements is well-defined. Since $g_L + g_T = 3.28f_L + .016f_T$, you want $3.28f_L + .016f_T = c(f_L + f_T)$, so you need $(3.28-c)f_L = (c-.016)f_T$, and therefore $f_L = ((c-.016)/(3.28-c))f_T$. In other words, you need to be able to convert between length and time: length and time have to be different ways of measuring the same thing. Are they? At an elementary level they are not, and that is why you can't add length and time physically.
To add two physical measurements in a well-defined way, we have seen (for the examples of length and time) that the two quantities you're measuring have to be convertible into each other. In relativity, we learn that the speed of light is a fundamental physical speed, and if we decide it is truly fundamental we can use it to convert between length and time. In general relativity it is convenient to declare the speed of light to be 1, which sets a definite conversion between meters and seconds, or feet and seconds, or any preferred choice of measuring length and time so that the value of the speed of light using those systems of measurement turns out to be 1. (It's like our preference for radians to degrees because in calculus the use of radians makes certain coefficients in derivative formulas equal to 1.) Once you have a standard for turning length into time then you can add length and time, and then all you're doing is adding length and length. Google the term "Planck units" to see how fundamental physical theories lead to a way of converting between mass, length, and time.
I'll leave it to you to decide what this viewpoint has to say about the physical possibility of adding meters and feet. Hint: be careful about whether you're dealing with functions of the same object or different objects.
KCd
  • 364
Fundamentally there are no units in physics. The result if all measurements is always a dimensionless number. If you say that you measured the length of some object to be one meter, then the outcome of the measurement is not actually the dimensional quantity of one meter, what you actually did was to compare the length of the object with the length of some length standard and you got the dimensionless number of $1$ as the result of that.
Units are ultimately just human constructs, historically they originated from a lack of knowledge and means to be able to measure different quantities in terms of each other. E.g. apart from practical issues, before we knew about special relativity, it was also theoretically impossible to compare a length standard to a time standard in a way that would make sense from the point of view of fundamental physics. The fact that we still use different units for time intervals and lengths is purely for historical reasons, by keeping the old units we end up with extraneous conversion factors, in this case the speed of light, $c$.
Suppose then we dismiss the notion of units altogether and always work in natural units where $\hbar = c = G = 1$ in the literal sense where we also dismiss any notion of dimensions. Formally, the physics would still be the same good old physics, but it looks like we can't do dimensional analysis anymore. But since everything should follow from physics, that can't be right, so it must be possible to recover the results of dimensional analysis without ever invoking any dimensions or units. This is indeed possible and as I show below, doing so explains why it works.
Let's consider the case of special relativity, we want to derive the classical limit, but we will work in $c = 1$ units. We're not allowed to restore a dimensional $c$, but of course, we're free to introduce a dimensionless scaling parameter $c$ in certain equations and study a particular scaling limit of the theory. I have explained the details here. It should be no surprise that by putting $c$ back in the right places and taking the $c\to \infty$ limit, you will recover classical mechanics, even if you always maintain that $c$ is just a dimensionless rescaling parameter.
Now, in that scaling limit, you can no longer compare certain physical quantities that you could compare to each other before you take that limit, take e.g. energy and mass. Then if you consider some equation between physical variables valid in the scaling limit, then you should demand that there are no factors of $c$ present in any such relation, and it is this demand that is formally equivalent to dimensional analysis.
More in general, if you play the same game with $\hbar$ and $G$, ten you see that it's all a simple a matter of assuming a certain scaling limit so that scaling factors should not appear in an equation relating physical quantities that are defined in some appropriate scaling limit. You can also argue the other way around, by assuming the validity of dimensional analysis and then recognizing that you can always construct Planck quantities that have any arbitrary dimension, allowing you to relate any physical quantity to any other using any arbitrary function. But of course, the one you desire doesn't contain $\hbar$, $c$ or $G$, or at least not all of them. The question is then why not? The answer will have to involve some physical argument that effectively reduces to a scaling argument.
The scaling argument is thus a more fundamental argument, it can be applied to situations where standard dimensional analysis doesn't yield useful results. E.g. you can consider boundary layer theory in fluid dynamics, by rescaling the relevant equations you end up with variables that describe the flow velocity in terms of a distance from the boundary in the boundary layer. In the ideal case we've rescaled by an infinite amount so you cannot relate this distance variable to other position variables used outside of the boundary layer. So, effectively, a new dimension has appeared that splits the length variables into two incompatible quantities.
Count Iblis
  • 10,396
  • 25
  • 49
Physics is concerned with finding a mathematical model to describe and predict reality. Units are a convenient and useful way for us to distinguish between quantities that describe different facets of a system, and adding or subtracting quantities from these facets does not help us describe or predict reality. It is undefined just like adding vectors and scalars; it doesn't help us build a useful theory just like adding scalars and vectors doesn't help mathematicians build a useful theory. The rules are the product of comparing experiment with the model; they are not arbitrary.
There might be some equation in which you can use the product of mass and period to describe a comet's motion; I couldn't say off-hand. But our definition of "speed" is just labeling some particular concept in our mathematical model. (It could also be described as the rate of change in distance.) The choice of "speed" is just semantics. The name itself is arbitrary aside from the fact that listeners understand it to convey a certain meaning, but now I'm describing how language works instead of physics.
So if you can find an experimentally verifiable formula that involves adding numbers of different units, then we would consider doing it and figuring out more about how it works. (You would also be famous among scientists, I imagine.) But until that happens, we'll continue using this rule of thumb.
jpmc26
  • 199
Surely you can add or multiply any two numbers, those are indeed simple mathematical operations. But physics is not math, it is physics. We attach units to values to represent something physical and therefore units have meaning.
While a meter-second could have some use (via multiplication), it's impossible to add two differing units. Can you really move 5 meters and 10 seconds? Sure you can move 5 meters in 10 seconds (division), but going 5 meters and 10 seconds is a meaningless statement.
Lastly, speed is given in units of length per unit time (e.g. meters per second or miles per hour). Mass is given in kilograms and period in seconds, multiplying them you get kilogram-seconds, which isn't anything like meters per second, so you cannot get a velocity from multiplying mass and time, not matter how much you might try.
Kyle Kanos
  • 29,127
I'll add a mathematical companion to the existing answers.
We are often interested in one-dimensional real vector spaces. While every such thing is just isomorphic to $\mathbb{R}$, there is practical value in keeping them separate.
If you have a vector $\vec{v}$ in one vector space (e.g. a vector space of possible signed distance measures) and another vector $\vec{w}$ in another vector space (e.g. a vector space of possible signed duration measures), it simply doesn't make sense to ask for $\vec{v} + \vec{w}$.
We still need to be able to compute with such things; the typical method is to pick a unit (e.g. maybe the vector space has an object we call "meter"), and then elements of this vector space can be obtained by multiplying a real number by the unit; e.g. $3.5 \ \mathrm{meter}$.
But remember we're keeping our vector spaces straight; $3.5 \ \mathrm{meter}$ is not a real number; it is a member of the vector space that $\mathrm{meter}$ came from. It only makes sense to add it to other quantities from the same vector space.
But what about multiplication? In linear algebra there is a notion of a tensor product which lets you multiply vectors from two vector spaces and produce an element of a third.
(technical detail: we use a specific construction of the tensor product on one-dimensional real vector spaces so as to be strict and symmetric)
E.g. If we multiply $\mathrm{meter}$ by $\mathrm{second}^{-1}$, we get an element in a third vector space, which we write as $\frac{\mathrm{meter}}{\mathrm{second}}$. We can make sense of division too, if we want. The various products involved are jointly associative and commutative, so the usual arithmetic is correct:
$$ (3 \ \mathrm{meter}) \cdot (5 \ \mathrm{second}^{-1}) = (3 \cdot 5) \frac{\mathrm{meter}}{\mathrm{second}}$$
Sorry for my english !
Above all, I want to say that I totally share everything that has been said before about dimensional analysis and homogeneity of equations. But as often in physics, things can be more subtle.
You can consult an old book quite remarkable and often reissued : "Dimensional analysis", P. W. Bridgman.
In this book, you will find the equations : (evidently, it's about free fall in gravity field. We have $v=gt$ and $s=\frac{1}{2}g{{t}^{2}}$) :
$s+v=gt+\frac{1}{2}g{{t}^{2}}$
"This is obviously a complete equation in that it is true and remain true no matter how the fundamental units of lenght and time are changed in size" (p 42 of my 1922 edition)
or worse :
$v{{\left( \sin \left( \frac{s+gt}{v} \right) \right)}^{\sinh \left( s-\frac{1}{2}g{{t}^{2}} \right)}}=gt\cosh \left( v-gt \right)$
"This again is a complet equation; it is not dimensinally homogeneous, and also offends our preconceived notions of what is possible in the way of transcendental functions" (p 42 of my 1922 edition)
"The possibility of equations like those just considered is in itself a refutation of the intuitional method of proof of the principle of dimensional homogeneity somtimes given" (p 42 of my 1922 edition)
And we remember Feynman's joke about a unified theory of physics, which in the idea was of the form (I do not remember where I read it) :
${{\left( \overrightarrow{g}-\frac{GM}{{{r}^{2}}}\overrightarrow{{{e}_{r}}} \right)}^{2}}+{{\left( \overrightarrow{\nabla }\wedge \overrightarrow{E}+\frac{\partial \overrightarrow{B}}{\partial t} \right)}^{2}}+.....=0$
In my opinion, you can very well add 10 meters and 5 seconds. The answer then is just "10m + 5s". If that is the answer to your computation of how long a metal rod should be, then that is okay. If you now go to a person that should manufacture that rod for you, he will ask "how long should it be?". If you tell him "15", he will say "15 what?". Quite understandably - I think I do not have to explain the need for units here. So you then tell him "10 meters + 5 seconds", he will tell you, he cannot do that. So the usefulness of this expression is limited. So you might think you can convert that into something he can work with, e.g. "15m". But here you should reason why this is the right value to choose. Noone gave a satisfying reasoning so far.
The mathematical analogon to this is probably "what is 10 + 5i?". Maybe it is 15? But no, it is just "10 + 5i". I would argue that in the same way as $\Bbb C$ is a field extension of $\Bbb R$ by $i$, so are the usual everyday quantities physicists encounter actually elements of a field $\Bbb R$ extended by trancendentals (your units) m, s, etc. With this you can make arbitrary wild expressions as
$$\frac{10 \mathrm m+ 5\mathrm s}{2 \mathrm{kg} - \mathrm m}.$$
The only problem that occurs is when you try to apply this to the real word. Then you have to think about how to convert this back into "how many ticks of my clock" or "how many lines on my measuring bar". If you find a consistent way to do that, you should tell us.
M. Winter
  • 531
