My teacher explained that when an external load is applied on an object in space ,eccentric to its centre of mass, the object will be accelerated linearly(along a straight line) because there will be no resisting forces(like friction).He also added that when the same load is applied to an object lying on a suface in earth, the object rotates (because of the resisting forces) and also moves linearly.But mass resists change in state of motion.So even in space the centre of mass will be the point at which the effect of entire mass will be cocentrated.So even if there is no other resistive forces,the object should rotate.Is this right?
Asked
Active
Viewed 121 times
The law of conservation of angular momentum has to hold.
If the hit is eccentric, i.e. the force vector direction does not pass through the center of mass, an angular impulse (See this article paragraph 19.5 .) is transferred to the body, and this will result in a rotation about the center of mass, because angular momentum is conserved.
anna v
- 236,935
