Let's consider Poisson bracket
$$\left\{ A,B\right\} =\alpha_{p} \left( \frac{\partial A}{\partial p_{k}}\frac{\partial B}{\partial q^{k}}-\frac{% \partial A}{\partial q^{k}}\frac{\partial B}{\partial p_{k}}\right) \tag{1}$$
where $\alpha _{p}=\pm 1;$ then
$$\frac{dA}{dt}=\frac{1}{% \alpha_{p}}\left\{ H,A\right\} \tag{2}$$ we know relation between Poisson bracket and commutator
$$\left\{ \hat{O}_{A},\hat{O}_{B}\right\} =i \alpha_{c}\left[ \hat{O}_{A},\hat{O}_{B}\right] \tag{3}$$
then Heisenberg equation
$$\frac{d\hat{A}}{dt}=\frac{i \alpha_{c}% }{\alpha_{p} }\left[ \hat{H},\hat{A}\right] \tag{4}$$
for momentum and coordinate
$$\frac{d\hat{p}}{dt}=\frac{i \alpha_{c}}{\alpha_{p} }\left[ \hat{H},\hat{p}\right] \qquad\text{and} \qquad\frac{d\hat{q}}{dt}=\frac{i \alpha_{c}}{\alpha_{p} }\left[ \hat{H},\hat{q}% \right] \tag{5}$$
finally we get
$$\frac{i \alpha_{c}}{\alpha_{p} }\frac{\partial \psi }{\partial t}=H\psi\tag{6} $$
so there are two independent parameters $\alpha_{c}$ and $\alpha_{p} $ I can choose $\alpha_{c}=1$ and $\alpha_{p}=-1$.
Is that computation correct?
Paramore
  • 151
  1. With the standard CCR $$[\hat{q},\hat{p}]~=~i\hbar{\bf 1}, \tag{A}$$ and with OP's convention (1) for the Poisson bracket $$\{p,q\}_{PB}~=~\alpha_p,\tag{B}$$ the operator $\leftrightarrow$ function correspondence reads
    $$ [\hat{f},\hat{g}]\quad\longleftrightarrow\quad\frac{\hbar}{i\alpha_p}\{f,g\}_{PB} +{\cal O}(\hbar^2) .\tag{C}$$ Note that the traditional physics convention is $\alpha_p=-1$. See e.g. this related Phys.SE post.
  2. Now let's address OP's title question. The time-dependent Schrödinger equation (TDSE) $$ i\hbar \frac{d |\psi \rangle}{d t}~=~\hat{H}|\psi \rangle, \tag{D}$$ and the Heisenberg equation $$ \frac{d\hat{f}}{dt}~=~\frac{i}{\hbar}[\hat{H},\hat{f}] + \frac{\partial \hat{f}}{\partial t}, \tag{E}$$ are independent of the Poisson bracket convention (1); while Hamilton's/Liouville's equation $$ \frac{df}{dt}~=~\frac{1}{\alpha_p}\{H,f\}_{PB} + \frac{\partial f}{\partial t}, \tag{F}$$ does depend on the Poisson bracket convention (1).
  3. For discussions of non-standard sign conventions in the TDSE, see e.g. this & this Phys.SE posts.
Because you add a sign to the Poisson brackets, you should do the same to the commutator for the relation
$$\left\{\hat{O}_{A},\hat{O}_{B}\right\}\leftrightarrow i\left[\hat{O}_{A},\hat{O}_{B}\right]$$
to still hold. Thus you just define the Poisson brackets/commutator differently, keeping the explicit equations the same. There is no point of doing this.
EDIT 1: The time evolution of a quantity in analytical mechanics is unique
$$\frac{dA}{dt}=\left\{A,H\right\}$$
with the regular definition of the Poisson brackets. Also Ehrenfest's theorem is unique
$$\frac{d\left<\hat{A}\right>}{dt}=\frac{1}{i\hbar}\left<\left[\hat{A},\hat{H}\right]\right>$$
with the regular definition of the commutator. This leads us to the usual correspondence
$$\left\{A,B\right\}\leftrightarrow\frac{1}{i\hbar}\left[\hat{A},\hat{B}\right]$$
If for some reason you want to change the usual definitions and write
$$\left\{A,B\right\}_{\rm OP}=\alpha_{\rm PB}\left\{A,B\right\}$$
$$\left[\hat{A},\hat{B}\right]_{\rm OP}=\alpha_{\rm C}\left[\hat{A},\hat{B}\right]$$
then all the above equations change accordingly, but that's only because you defined something differently. It is only a cosmetic change.
eranreches
  • 4,249
