-4
Please read this http://www.researchgate.net/publication/282157370_VALUE_OF_THE_UNIVERSE%27S_ACCELERATION
Your ideas are welcome.
The universe is described by a scale factor, normally indicated by the symbol $a(t)$, that is a function of time. We take the scale factor to be one right now, so in the past $a$ was less than one and in the future $a$ will be greater than one.
Roughly speaking, if $a$ has the value $\tfrac{1}{2}$ it means everything was half as far apart as it is now, and if $a$ has the value $2$ it means everything is twice as far apart as it is now. So the scale factor measures the expansion of the universe.
If dark matter didn't exist we would expect the variation of $a$ with time to be:
$$ a(t) \propto t^{2/3} $$
So the rate of change of $a$ with time (we write this as $\dot{a}(t)$) would be given by:
$$ \dot{a}(t) \propto \frac{1}{t^{1/3}} $$
So as $t$ increases the rate of the expansion, $\dot{a}(t)$, will decrease. This is what we mean by a decelerating expansion, and as I mentioned above if dark energy didn't exist we would expect the expansion to decelerate.
However the presence of dark energy adds a term to the rate of expansion that is something like:
$$ \dot{a}(t) \propto e^{bt} $$
where $b$ is a constant. So dark energy makes the rate of expansion, $\dot{a}(t)$, increase not decrease. This is what we mean by an accelerating expansion.
If you're interested I go into the maths in more detail in my answer to How does the Hubble parameter change with the age of the universe?.
So the acceleration of the expansion is represented by the change in $\dot{a}(t)$, and we know this to reasonable precision. The paper you cite is attempting to construct a rate of acceleration from the velocities of distant objects. However this does not correspond to what cosmologists mean by the acceleration of the expansion.
John Rennie
  • 367,598
