I have installed Home Assistant to Sonoff NSPanel Pro according to this guide:
https://blakadder.com/android-panel-webview/
Finally I installed the Home Assistant.
When I tried to connect to my Home Assistant, I got a certificate error due to my local home assistant using my own CA in local area network.
I have tried to add my own CA certificate to android
https://stackoverflow.com/a/46569793/5728926
But it seems to me that it does not work. Home Assistant shows a certificate error and I cannot ignore it.
How can I add my own CA certificate to Sonoff NS Panel Pro?
Rohit Gupta
  • 507
  • 18
Dániel Kis
  • 121
I finally found a solution that worked. Copy the files to /sdcard/Download with adb push or download the certificates with your browser. Start files and go to Download and click on the certificate. Android asks if you want to setup a the lock screen. Click yes and then setup a pin. Now you can install the certificate for VPN and apps.
