I'd like to list all enabled service instances.
The following lists enabled services, but only shows the service, and not individual instance:
systemctl list-unit-files --state=enabled
The following lists all running instances:
systemctl list-units --state=running
I would expect something like the following to show enabled instances:
systemctl list-units --state=enabled
But that does not work.
So, if I start two service instances with:
systemctl start foo-service@primary
systemctl start foo-service@secondary
...but then I only enable one:
systemctl enable foo-service@secondary
The only way I've been able to find out which instances are enabled is with:
ls /etc/systemd/system/multi-user.target.wants/
But that seems very kludge-y. Is there a systemd way of doing this? Version is 232 if it matters.
