I just installed Kubuntu 17.04 on a Lenovo Ideapad 320, and the Touchpad is not detected. The touchpad works fine from the Windows 10 installation already on the laptop, but is not detected at all from Kubuntu, so it seems like a driver error.
Here is the xinput output. The Logitech mouse is a USB mouse I am using in the meantime, which works fine.
$ xinput --list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Logitech M315/M235 id=9 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ EasyCamera id=10 [slave keyboard (3)]
↳ Ideapad extra buttons id=11 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=12 [slave keyboard (3)]
And:
$ cat /proc/bus/input/devices | grep TouchPad
Has no output. I have also tried the psmouse-related stuff suggested here to no avail
It seems like I'm not the only one, this is posted a few other places with no answer, here and here, and maybe here
Edit:
dpkg output:
$ dpkg -i elantech...
Selecting previously unselected package
elantech-0608-dkms.
(Reading database ... 267979 files and directories currently installed.)
Preparing to unpack elantech-0608-dkms_0.1_all.deb ...
Unpacking elantech-0608-dkms (0.1) ...
Setting up elantech-0608-dkms (0.1) ...
Loading new elantech-0608-0.1 DKMS files...
Building for 4.10.0-32-generic
Building for architecture x86_64
Building initial module for 4.10.0-32-generic
Done.
psmouse:
Running module version sanity check.
Error! Module version 69C24E88441CC55A8AC9337 for psmouse.ko
is not newer than what is already found in kernel 4.10.0-32-generic
(69C24E88441CC55A8AC9337).
You may override by specifying --force.
depmod...
Backing up initrd.img-4.10.0-32-generic to /boot/initrd.img-4.10.0-32-
generic.old-dkms
Making new initrd.img-4.10.0-32-generic
(If next boot fails, revert to initrd.img-4.10.0-32-generic.old-dkms image)
update-initramfs........
DKMS: install completed.
Processing triggers for shim-signed (1.32~17.04.1+0.9+1474479173.6c180c6-1ubuntu1) ...
Installing version 0.2:
$ sudo dkms install --force elantech-0608/0.2
Error! Could not find module source directory.
Directory: /usr/src/elantech-0608-0.2 does not exist.
And it is installed:
$ apt search elantech
Sorting...
Full Text Search...
elantech-0608-dkms/now 0.2 all [installed,local]
elantech-0608 driver in DKMS format.
