I just installed and updated a Ubuntu Xenial with Unity on Dell Vostro 14 3446 laptop. Earlier, I have used Ubuntu Trusty and Linux Mint 17 and 18 on this same laptop and the touchpad has never given any problems. Now, it has both vertical and horizontal scrolling enabled by default and I can't find a way to disable the horizontal scrolling.
$ xinput -list
⎡ Virtual core pointer                      id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ DLL0662:00 06CB:2985                      id=12   [slave  pointer  (2)]
⎜   ↳ SynPS/2 Synaptics TouchPad                id=14   [slave  pointer  (2)]
⎣ Virtual core keyboard                     id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Video Bus                                 id=8    [slave  keyboard (3)]
    ↳ Power Button                              id=9    [slave  keyboard (3)]
    ↳ Sleep Button                              id=10   [slave  keyboard (3)]
    ↳ Integrated_Webcam_HD                      id=11   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=13   [slave  keyboard (3)]
    ↳ Dell WMI hotkeys                          id=15   [slave  keyboard (3)]
This is what I have tried yet:
  1. Removed xserver-xorg-input-synaptics and xserver-xorg-input-evdev, installed xserver-xorg-input-libinput and restarted. This resulted in Tap-to-Click getting disabled and the Touchpad settings disappearing. libinput was uninstalled after this and synaptic driver reinstalled.
  2. Executed synclient HorizTwoFingerScroll=0. After doing this, synclient | grep -i horiz prints this:
    HorizScrollDelta = 110 HorizEdgeScroll = 0 HorizTwoFingerScroll = 0 HorizHysteresis = 27
And yet, horizontal scrolling is still on.
Is there any way to disable this? Linux Mint 18 Cinnamon gave an option to disable it, so it's definitely possible. But how?
strNOcat
  • 445
It is quite easy to do if you installed libinput.
Edit /usr/share/X11/xorg.conf.d/xx-libinput.conf ( replace the xx with the right number for your system; often 90 or 40 ) and add
Option "HorizontalScrolling" "False"
to the touchpad section.
xorg-synapics and libinput have different config files.
Option "Tapping" "True"
will enable tap-to-click function. It is disabled by default.
You can see the full list of options HERE
Pilot6
  • 92,041
An easier way (from https://askubuntu.com/a/338312/48493), that worked for me on Ubuntu 17.04. This is for on-the-fly changes to setttings, however:
jdpipe
  • 809
