Error message
BusyBox v1.21.1 (Ubuntu 1:1.21.0-1ubuntu1) built-in shell (ash) Enter 'help' for a list of built in commands.
(initramfs) Mount is denied because the NTFS volume is already exclusively opened. The volume may be already mounted, or another software may use it which could be identified for example by the help of the 'fuser' command. mount: mounting /dev/dm-2 on /tmpmountpoint failed: No such device /scripts/casper-premount/30custom-installation: line 100: can't open /dev/sr0: No medium found
Could not find the installation files /ubuntu/install/custom-installation This could also happen if the file system is not clean because of an operating system crash, an interrupted boot process, an improper shutdown, or unplugging of a removable device without first unmounting or ejecting it. To fix this, simply reboot into Windows, let it fully start, log in, run 'chkdsk /r', then gracefully shut down and reboot back into Windows. After this you should you should be able to reboot again and resume the installation.
Logs
09-20 18:19 INFO   root: === wubi 14.04 rev286 ===
09-20 18:19 DEBUG  root: Logfile is c:\users\uczen\appdata\local\temp\wubi-14.04-rev286.log
09-20 18:19 DEBUG  root: sys.argv = ['main.pyo', '--exefile="C:\\Users\\uczen\\Desktop\\linux\\wubi.exe"']
09-20 18:19 DEBUG  CommonBackend: data_dir=C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp\data
09-20 18:19 DEBUG  WindowsBackend: 7z=C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp\bin\7z.exe
09-20 18:19 DEBUG  WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
09-20 18:19 DEBUG  CommonBackend: Fetching basic info...
09-20 18:19 DEBUG  CommonBackend: original_exe=C:\Users\uczen\Desktop\linux\wubi.exe
09-20 18:19 DEBUG  CommonBackend: platform=win32
09-20 18:19 DEBUG  CommonBackend: osname=nt
09-20 18:19 DEBUG  CommonBackend: language=pl_PL
09-20 18:19 DEBUG  CommonBackend: encoding=cp1250
09-20 18:19 DEBUG  WindowsBackend: arch=amd64
09-20 18:19 DEBUG  CommonBackend: Parsing isolist=C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp\data\isolist.ini
09-20 18:19 DEBUG  CommonBackend:   Adding distro Edubuntu-i386
09-20 18:19 DEBUG  CommonBackend:   Adding distro Kubuntu-amd64
09-20 18:19 DEBUG  CommonBackend:   Adding distro Mythbuntu-i386
09-20 18:19 DEBUG  CommonBackend:   Adding distro Edubuntu-amd64
09-20 18:19 DEBUG  CommonBackend:   Adding distro Ubuntu Studio-amd64
09-20 18:19 DEBUG  CommonBackend:   Adding distro Ubuntu-amd64
09-20 18:19 DEBUG  CommonBackend:   Adding distro Lubuntu-i386
09-20 18:19 DEBUG  CommonBackend:   Adding distro Ubuntu-i386
09-20 18:19 DEBUG  CommonBackend:   Adding distro Mythbuntu-amd64
09-20 18:19 DEBUG  CommonBackend:   Adding distro Kubuntu-i386
09-20 18:19 DEBUG  CommonBackend:   Adding distro Ubuntu Studio-i386
09-20 18:19 DEBUG  CommonBackend:   Adding distro Lubuntu-amd64
09-20 18:19 DEBUG  WindowsBackend: Fetching host info...
09-20 18:19 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
09-20 18:19 DEBUG  WindowsBackend: windows version=vista
09-20 18:19 DEBUG  WindowsBackend: windows_version2=Windows 7 Professional
09-20 18:19 DEBUG  WindowsBackend: windows_sp=None
09-20 18:19 DEBUG  WindowsBackend: windows_build=7600
09-20 18:19 DEBUG  WindowsBackend: gmt=1
09-20 18:19 DEBUG  WindowsBackend: country=PL
09-20 18:19 DEBUG  WindowsBackend: timezone=Europe/Warsaw
09-20 18:19 DEBUG  WindowsBackend: windows_username=uczen
09-20 18:19 DEBUG  WindowsBackend: user_full_name=uczen
09-20 18:19 DEBUG  WindowsBackend: user_directory=C:\Users\uczen
09-20 18:19 DEBUG  WindowsBackend: windows_language_code=1045
09-20 18:19 DEBUG  WindowsBackend: windows_language=Polish
09-20 18:19 DEBUG  WindowsBackend: processor_name=AMD Athlon(tm) II X2 245 Processor
09-20 18:19 DEBUG  WindowsBackend: bootloader=vista
09-20 18:19 DEBUG  WindowsBackend: system_drive=Drive(C: hd 933439.820313 mb free ntfs)
09-20 18:19 DEBUG  WindowsBackend: drive=Drive(C: hd 933439.820313 mb free ntfs)
09-20 18:19 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
09-20 18:19 DEBUG  WindowsBackend: uninstaller_path=C:\ubuntu\uninstall-wubi.exe
09-20 18:19 DEBUG  WindowsBackend: previous_target_dir=C:\ubuntu
09-20 18:19 DEBUG  WindowsBackend: previous_distro_name=Ubuntu
09-20 18:19 DEBUG  WindowsBackend: keyboard_id=68486165
09-20 18:19 DEBUG  WindowsBackend: keyboard_layout=pl
09-20 18:19 DEBUG  WindowsBackend: keyboard_variant=
09-20 18:19 DEBUG  CommonBackend: python locale=('pl_PL', 'cp1250')
09-20 18:19 DEBUG  CommonBackend: locale=pl_PL.UTF-8
09-20 18:19 DEBUG  WindowsBackend: total_memory_mb=4095.3671875
09-20 18:19 DEBUG  CommonBackend: Searching ISOs on USB devices
09-20 18:19 DEBUG  CommonBackend: Searching for local CDs
09-20 18:19 DEBUG  Distro:   checking whether C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp is a valid Ubuntu CD
09-20 18:19 DEBUG  Distro:     does not contain C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp\casper\filesystem.squashfs
09-20 18:19 DEBUG  Distro:   checking whether C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp is a valid Kubuntu CD
09-20 18:19 DEBUG  Distro:   checking whether C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp is a valid Mythbuntu CD
09-20 18:19 DEBUG  Distro:   checking whether C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp is a valid Edubuntu CD
09-20 18:19 DEBUG  Distro:   checking whether C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp is a valid Lubuntu CD
09-20 18:19 DEBUG  Distro:   checking whether C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp is a valid Ubuntu Studio CD
09-20 18:19 DEBUG  Distro:   checking whether D:\ is a valid Ubuntu CD
09-20 18:19 DEBUG  Distro:     does not contain D:\casper\filesystem.squashfs
09-20 18:19 DEBUG  Distro:   checking whether D:\ is a valid Kubuntu CD
09-20 18:19 DEBUG  Distro:   checking whether D:\ is a valid Mythbuntu CD
09-20 18:19 DEBUG  Distro:   checking whether D:\ is a valid Edubuntu CD
09-20 18:19 DEBUG  Distro:   checking whether D:\ is a valid Lubuntu CD
09-20 18:19 DEBUG  Distro:   checking whether D:\ is a valid Ubuntu Studio CD
09-20 18:19 INFO   root: Already installed, running the uninstaller...
09-20 18:19 INFO   root: Running the uninstaller...
09-20 18:19 INFO   CommonBackend: This is the uninstaller running
09-20 18:19 DEBUG  WindowsFrontend: __init__...
09-20 18:19 DEBUG  WindowsFrontend: on_init...
09-20 18:19 INFO   WinuiPage: appname=wubi, localedir=C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp\translations, languages=['pl_PL', 'pl']
09-20 18:19 INFO   root: Received settings
09-20 18:19 DEBUG  TaskList: # Running tasklist...
09-20 18:19 DEBUG  TaskList: ## Running Usuwanie wpisu programu uruchomieniowego...
09-20 18:19 DEBUG  WindowsBackend: Could not find bcd id
09-20 18:19 DEBUG  WindowsBackend: undo_bootini C:
09-20 18:19 DEBUG  WindowsBackend: undo_configsys Drive(C: hd 933439.820313 mb free ntfs)
09-20 18:19 DEBUG  TaskList: ## Finished Usuwanie wpisu programu uruchomieniowego
09-20 18:19 DEBUG  TaskList: ## Running Usuwanie katalogu docelowego...
09-20 18:19 DEBUG  CommonBackend: Deleting C:\ubuntu
09-20 18:19 DEBUG  TaskList: ## Finished Usuwanie katalogu docelowego
09-20 18:19 DEBUG  TaskList: ## Running Usuwanie wpisów rejestru...
09-20 18:19 DEBUG  TaskList: ## Finished Usuwanie wpisów rejestru
09-20 18:19 DEBUG  TaskList: # Finished tasklist
09-20 18:19 INFO   root: Almost finished uninstalling
09-20 18:19 INFO   root: Finished uninstallation
09-20 18:19 DEBUG  WindowsBackend: system_drive=Drive(C: hd 933442.953125 mb free ntfs)
09-20 18:19 DEBUG  WindowsBackend: drive=Drive(C: hd 933442.953125 mb free ntfs)
09-20 18:19 DEBUG  WindowsBackend: uninstaller_path=None
09-20 18:19 DEBUG  WindowsBackend: previous_target_dir=None
09-20 18:19 DEBUG  WindowsBackend: previous_distro_name=None
09-20 18:19 INFO   root: Running the installer...
09-20 18:19 DEBUG  WinuiInstallationPage: target_drive=C:, installation_size=18000MB, distro_name=Ubuntu, language=pl_PL, locale=pl_PL.UTF-8, username=uczen
09-20 18:19 DEBUG  CommonBackend: Searching for local ISO
09-20 18:19 DEBUG  Distro:   checking Ubuntu ISO C:\Users\uczen\Desktop\linux\Triumfalna-Turkawka-14.04.1PL-DVD-amd64.iso
09-20 18:19 DEBUG  WindowsBackend:   extracting .disk\info from C:\Users\uczen\Desktop\linux\Triumfalna-Turkawka-14.04.1PL-DVD-amd64.iso
09-20 18:19 DEBUG  Distro:   parsing info from str=Ubuntu 14.04.1 LTS "Trusty Tahr" - Release amd64 (20140722.2)
09-20 18:19 DEBUG  Distro:   parsed info={'name': 'Ubuntu', 'subversion': 'Release', 'version': '14.04.1', 'build': '20140722.2', 'codename': 'Trusty Tahr', 'arch': 'amd64'}
09-20 18:19 INFO   Distro: Found a valid iso for Ubuntu: C:\Users\uczen\Desktop\linux\Triumfalna-Turkawka-14.04.1PL-DVD-amd64.iso
09-20 18:19 DEBUG  TaskList: ## Running select_target_dir...
09-20 18:19 INFO   WindowsBackend: Installing into C:\ubuntu
09-20 18:19 DEBUG  TaskList: ## Finished select_target_dir
09-20 18:19 DEBUG  TaskList: ## Running create_dir_structure...
09-20 18:19 DEBUG  CommonBackend: Creating dir C:\ubuntu
09-20 18:19 DEBUG  CommonBackend: Creating dir C:\ubuntu\disks
09-20 18:19 DEBUG  CommonBackend: Creating dir C:\ubuntu\install
09-20 18:19 DEBUG  CommonBackend: Creating dir C:\ubuntu\install\boot
09-20 18:19 DEBUG  CommonBackend: Creating dir C:\ubuntu\disks\boot
09-20 18:19 DEBUG  CommonBackend: Creating dir C:\ubuntu\disks\boot\grub
09-20 18:19 DEBUG  CommonBackend: Creating dir C:\ubuntu\install\boot\grub
09-20 18:19 DEBUG  TaskList: ## Finished create_dir_structure
09-20 18:19 DEBUG  TaskList: ## Running uncompress_target_dir...
09-20 18:19 DEBUG  TaskList: ## Finished uncompress_target_dir
09-20 18:19 DEBUG  TaskList: ## Running create_uninstaller...
09-20 18:19 DEBUG  WindowsBackend: Copying uninstaller C:\Users\uczen\Desktop\linux\wubi.exe -> C:\ubuntu\uninstall-wubi.exe
09-20 18:19 DEBUG  registry: Setting registry key -2147483646 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi UninstallString C:\ubuntu\uninstall-wubi.exe
09-20 18:19 DEBUG  registry: Setting registry key -2147483646 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi InstallationDir C:\ubuntu
09-20 18:19 DEBUG  registry: Setting registry key -2147483646 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayName Ubuntu
09-20 18:19 DEBUG  registry: Setting registry key -2147483646 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayIcon C:\ubuntu\Ubuntu.ico
09-20 18:19 DEBUG  registry: Setting registry key -2147483646 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayVersion 14.04-rev286
09-20 18:19 DEBUG  registry: Setting registry key -2147483646 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi Publisher Ubuntu
09-20 18:19 DEBUG  registry: Setting registry key -2147483646 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi URLInfoAbout http://www.ubuntu.com
09-20 18:19 DEBUG  registry: Setting registry key -2147483646 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi HelpLink http://www.ubuntu.com/support
09-20 18:19 DEBUG  TaskList: ## Finished create_uninstaller
09-20 18:19 DEBUG  TaskList: ## Running copy_installation_files...
09-20 18:19 DEBUG  WindowsBackend: Copying C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp\data\custom-installation -> C:\ubuntu\install\custom-installation
09-20 18:19 DEBUG  WindowsBackend: Copying C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp\winboot -> C:\ubuntu\winboot
09-20 18:19 DEBUG  WindowsBackend: Copying C:\Users\uczen\AppData\Local\Temp\pyl5A7E.tmp\data\images\Ubuntu.ico -> C:\ubuntu\Ubuntu.ico
09-20 18:19 DEBUG  TaskList: ## Finished copy_installation_files
09-20 18:19 DEBUG  TaskList: ## Running get_iso...
09-20 18:19 DEBUG  CommonBackend: Trying to use ISO C:\Users\uczen\Desktop\linux\Triumfalna-Turkawka-14.04.1PL-DVD-amd64.iso
09-20 18:19 DEBUG  TaskList: New task check_iso
09-20 18:19 DEBUG  TaskList: ### Running check_iso...
09-20 18:19 DEBUG  CommonBackend: Checking C:\Users\uczen\Desktop\linux\Triumfalna-Turkawka-14.04.1PL-DVD-amd64.iso
09-20 18:19 DEBUG  TaskList: New task get_metalink
09-20 18:19 DEBUG  TaskList: #### Running get_metalink...
09-20 18:19 DEBUG  downloader: downloading http://releases.ubuntu.com/14.04/ubuntu-14.04-desktop-amd64.metalink > C:\ubuntu\install
09-20 18:19 ERROR  CommonBackend: Cannot download metalink file http://releases.ubuntu.com/14.04/ubuntu-14.04-desktop-amd64.metalink err=[Errno 14] HTTP Error 404: Not Found
09-20 18:19 DEBUG  downloader: downloading http://cdimage.ubuntu.com/daily-live/current/trusty-desktop-amd64.metalink > C:\ubuntu\install
09-20 18:19 ERROR  CommonBackend: Cannot download metalink file2 http://cdimage.ubuntu.com/daily-live/current/trusty-desktop-amd64.metalink err=[Errno 14] HTTP Error 404: Not Found
09-20 18:19 DEBUG  TaskList: #### Finished get_metalink
09-20 18:19 ERROR  CommonBackend: ERROR: the metalink file is not available, cannot check the md5 for C:\Users\uczen\Desktop\linux\Triumfalna-Turkawka-14.04.1PL-DVD-amd64.iso, ignoring
09-20 18:19 DEBUG  TaskList: ### Finished check_iso
09-20 18:19 DEBUG  TaskList: New task copy_file
09-20 18:19 DEBUG  CommonBackend: Copying C:\Users\uczen\Desktop\linux\Triumfalna-Turkawka-14.04.1PL-DVD-amd64.iso > C:\ubuntu\install\installation.iso
09-20 18:19 DEBUG  TaskList: ### Running copy_file...
09-20 18:19 DEBUG  TaskList: ### Finished copy_file
09-20 18:19 DEBUG  TaskList: ## Finished get_iso
09-20 18:19 DEBUG  TaskList: ## Running extract_kernel...
09-20 18:19 DEBUG  CommonBackend: Extracting files from ISO C:\ubuntu\install\installation.iso
09-20 18:19 DEBUG  WindowsBackend:   extracting md5sum.txt from C:\ubuntu\install\installation.iso
09-20 18:19 DEBUG  WindowsBackend:   extracting casper\vmlinuz.efi from C:\ubuntu\install\installation.iso
09-20 18:19 DEBUG  WindowsBackend:   extracting casper\initrd.lz from C:\ubuntu\install\installation.iso
09-20 18:19 DEBUG  CommonBackend: Checking kernel, initrd and md5sums
09-20 18:19 DEBUG  CommonBackend:   checking C:\ubuntu\install\boot\vmlinuz.efi
09-20 18:19 DEBUG  CommonBackend:   C:\ubuntu\install\boot\vmlinuz.efi md5 = 2902c6e94b680dc5a068543b716118ca == 2902c6e94b680dc5a068543b716118ca
09-20 18:19 DEBUG  CommonBackend:   checking C:\ubuntu\install\boot\initrd.lz
09-20 18:19 DEBUG  CommonBackend:   C:\ubuntu\install\boot\initrd.lz md5 = 8c51b6fbad7a4cd0c9756a129a6d058a == 8c51b6fbad7a4cd0c9756a129a6d058a
09-20 18:19 DEBUG  TaskList: ## Finished extract_kernel
09-20 18:19 DEBUG  TaskList: ## Running choose_disk_sizes...
09-20 18:19 DEBUG  WindowsBackend: total size=18000
  root=17744
  swap=256
  home=0
  usr=0
09-20 18:19 DEBUG  TaskList: ## Finished choose_disk_sizes
09-20 18:19 DEBUG  TaskList: ## Running create_preseed...
09-20 18:19 DEBUG  TaskList: ## Finished create_preseed
09-20 18:19 DEBUG  TaskList: ## Running modify_bootloader...
09-20 18:19 DEBUG  TaskList: New task modify_bcd
09-20 18:19 DEBUG  TaskList: ### Running modify_bcd...
09-20 18:19 DEBUG  WindowsBackend: modify_bcd Drive(C: hd 933442.953125 mb free ntfs)
09-20 18:19 DEBUG  registry: Setting registry key -2147483646 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi VistaBootDrive {cc70e987-7f3c-11e6-82f3-edcbbc3288a4}
09-20 18:19 DEBUG  TaskList: ### Finished modify_bcd
09-20 18:19 DEBUG  TaskList: ## Finished modify_bootloader
09-20 18:19 DEBUG  TaskList: ## Running modify_grub_configuration...
09-20 18:19 DEBUG  TaskList: ## Finished modify_grub_configuration
09-20 18:19 DEBUG  TaskList: ## Running create_virtual_disks...
09-20 18:19 DEBUG  Virtualdisk:  Creating virtual disk C:\ubuntu\disks\root.disk of 17744MB
09-20 18:19 DEBUG  Virtualdisk:  Creating virtual disk C:\ubuntu\disks\swap.disk of 256MB
09-20 18:19 DEBUG  TaskList: ## Finished create_virtual_disks
09-20 18:19 DEBUG  TaskList: ## Running uncompress_files...
09-20 18:19 DEBUG  WindowsBackend: compact C:\ubuntu\install\boot /U /A /F
09-20 18:19 DEBUG  WindowsBackend: compact C:\ubuntu\install\boot\*.* /U /A /F
09-20 18:19 DEBUG  TaskList: ## Finished uncompress_files
09-20 18:19 DEBUG  TaskList: ## Running eject_cd...
09-20 18:19 DEBUG  TaskList: ## Finished eject_cd
09-20 18:19 INFO   root: Almost finished installing
09-20 18:19 INFO   root: Finished installation
09-20 18:19 DEBUG  root: application.quit
09-20 18:19 DEBUG  WindowsFrontend: frontend.quit
09-20 18:19 DEBUG  WindowsFrontend: frontend.on_quit
09-20 18:19 DEBUG  root: application.on_quit
09-20 18:19 INFO   root: sys.exit
So I can't run and Install Ubuntu.
karel
  • 122,292
  • 133
  • 301
  • 332
NiceJJ
Wubi is not supported on Ubuntu 14.04; it has a whole host of problems, doesn't work with EFI, and is for the most part obsolete and not updated. Do not use Wubi, and instead do a true dual boot.
Also the mountpoint of /dev/dm-2 should be /tmp/mountpoint instead of /tmpmountpoint The mountpoint may be important depending on what you are trying to do with this operating system. Further information explaining what you are trying to do may be required. Read the comments for suggestions about this.
karel
  • 122,292
  • 133
  • 301
  • 332
Do not use Wubi, it is no longer supported.
Please download an ISO of your preferred Ubuntu variant (such as Ubuntu 16.04 LTS 64-bit), get a flash drive, and use Rufus on Windows or dd on Linux to create a bootable flash drive. Boot it and install the OS properly with the installation wizard. The installer should be able to detect your Windows installation still, but you'll need to wipe the previous (failed?) Ubuntu installation.
Aaron Franke
  • 1,136
