I wish to switch from Windows 7 to Ubuntu, and I'm trying to figure which (LTS) release should I use, whether to use the newest (16.04), an older one or one of the light-weight flavours (my computer is a bit old - bought on october 2010). My specs are:
  • Dell Inspiron N4030
  • Intel Core i3-350M, 2.26GHz
  • 3GB RAM
  • ATI Radeon HD530 512MB
  • Currently running Windows 7 64-bit
My usage is quite standard - internet, photos, videos, word-processing (mainly using LyX for LaTeX).
Thanks.
Ur Ya'ar
  • 287
The latest LTS (Long Term Support) version would suit you just fine. Go with the 32x version. You can download it from the main download page.
http://www.ubuntu.com/download/desktop
If it's too slow, try LXDE. sudo apt-get install lxde-desktop
LXDE and openbox will then be available on the login screen. (After you log out, not lock.)
Openbox is fast, LXDE is easy.
Mrlong2
  • 123
With the specs you provided I think a lighter distribution would do well on that machine. Try Lubuntu, it is a great light weight desktop environment that requires very little resources
If you would also like to read what the requirements are to run Ubuntu 16.04, you can start here: Ubuntu installation requirements in most cases it's better to have more Ram then what's required as Ubuntu is developed is also consumes more of our system system resources
I would also recommend sticking with the LTS releases because they are supported for a number of years, here is a chart that will give you a break down on what to expect with LTS releases, LTS, Long Term Support
Rob Goss
  • 116
