I installed Windows 7 and 64 bit Ubuntu 14.04 LTS on my PC and both worked very smoothly. Since I updated by ubuntu last month, the system starts directly to ubuntu OS. I can't see GRUB menu, which normally appears asking for windows or ubuntu OS boot option.
Asked
Active
Viewed 572 times
install the grub customiser from synaptic package manager or ubuntu software Center .By using grub customizer you can load the grub and save it.
Sudip Das
- 300
Hold down the SHIFT key when booting, and you should see the GRUB menu, where you can select which OS to boot.
Depending on how your GRUB is configured, it will remember the last choice you made in GRUB, or it won't, and you'll have to select Windows every time. More detail available if required.
Cheers, Al
heynnema
- 73,649
