Yesterday I got my first Ubuntu (11.10 32 bit) installation (wish me luck), and I ran into a problem with my USB network card.
I use a wireless USB stick by edimax (it is called IEEE802.11b/g/n nano USB adapter or also EW-7811Un).
My problem is that Ubuntu seems to be able to use the USB to see the networks around me, but when I try to connect to my network - it just keeps trying and failing.
I am connected to the internet through a
300M Wireless N Router Model No. TL-WR841N / TL-WR841ND
I have other computers in the house which are able to connect to the internet. And the same computer previously had Windows on it - and it managed to connect to the internet with no problem.
Can you please advise on how this can be resolved? (what output should I send you?)
Thanks!
Tal Galili
  • 895
  • 15
o.k., I solved the problem.
It took a bunch of steps - I have detailed them here:
http://www.r-statistics.com/2011/11/edimax-ew-7811un-usb-wireless-connecting-to-a-network-on-ubuntu-11-10/
Thank you Engels for your kind help! (I also gave credit in the post, and will gladly link to whatever website you might want from your name)
Tal Galili
  • 895
  • 15
If you are using Edimax EW-7811Un then the following (qouted from this site) should fix the problem:
Create this file /etc/modprobe.d/8192cu.conf and and the following lines to it:
# Disable power management
options 8192cu rtw_power_mgnt=0 rtw_enusbss=0
Then save it and reboot and the wifi adapter should work properly.
For more details about the above parameters and their values:
rtw_power_mgnt=0|1|2
    0 == disable power saving
    1 == power saving on, minPS
    2 == power saving on, maxPS
rtw_enusbss=0|1
    0 == disable auto suspend
    1 == enable auto suspend
razzak
  • 111
