Good evening, I have a problem to eliminate the annoying "tearing" of my current video card intel HD 3000 (Sandy Bridge CPU). Installing Ubuntu 10.11 (AMD64) the bug is now known (but does not seem resolved) is solved using unity - compiz (the solution is here: Screen tearing in 11.10 with intel graphics 11-10-with-intel-graphics), but I have no solutions for the Gnome Shell. thanks
luke71
  • 51
"You should not experience tearing if you disable compositing and use gl or vaapi output. Tearing still happens with xv/x11 due to vsync not working properly on Sandy Bridge yet, even with compositing disabled."
I confirm that this workaround works on my system with Intel/ATI Hybrid graphics, using Intel graphics as active. I'm in KDE, before playing video I will switch off KDE compositing (Alt+Shift+F2) then play video using mplayer with gl output. No tearing at all! :-) Finally, I can watch movies in great shape on my 32" HDMI TV ^_^
Using VLC still tears, because when with VLC-GLX the video is corrupted, and with XV there's still video tearing even with compositing disabled.
https://bugs.launchpad.net/ubuntu/+source/xserver-xorg-video-intel/+bug/755841/comments/101
Did some test here and I thinks I find out the origin of the issue (or workarround)
Basically if you:
- disable composite ( sorry till now I cannot find a better solution )
AND
- [VLC] deselect this option: Video -> Display -> Accelerated video output (Overlay)
OR
- [VLC] select this video output: Video -> Output -> OpenGL GLX
You will not have any Tearing
Postadelmaga
  • 5,759
As Eugeni Dodonov said (Intel Open source technology center member):
[...] when tearing free playback will be possible on Sandy Bridge?
You are hitting the unfamous bug https://bugs.freedesktop.org/show_bug.cgi?id=37686 . There is no fix for this at the moment, but I expect it to get fixed at some point.
Meanwhile, you can play videos without tearing on Sandy Bridge if you use GL or VAAPI video outputs and disable compositing (or use a compositor which plays fine with that). The bug itself have some tricks which you can try to get it working. But for real fix, no, it is not there yet, sorry.
Source (2012/01/13): http://phoronix.com/forums/showthread.php?68199-Intel-Wants-YOUR-Linux-Questions-Feedback&p=246801#post246801
On the other hand, if you've hit by this bug then you should install the latest kernel version, as of 2012 January the 3.2.1 one. The 3.2 release was the first to include the patch and it solved all the tearing issues I had.
Indeed the sandy bridge support really improved over the course of the past year and unless you have a good reason to stick with the 11.10 stock kernel you should at least try an upgrade.
Maxime R.
  • 3,920
Place the following in to /etc/environment and reboot:
CLUTTER_PAINT=disable-clipped-redraws:disable-culling
Reference, and other useful info: https://bbs.archlinux.org/viewtopic.php?pid=1018579#p1018579
benwh
  • 570
