I've just installed ubuntu server 16.04 but it won't boot. Here's the only thing I get on screen:
lvmetad is not active yet; using direct activation during sysinit
/dev/mapper/server--vg-root: clean xxx/xxx files, xxx/xxx blocks
"xxx" are some large numbers I can't even use the command line so I'm stucked. Any ideas?
Ckubrak
  • 313
I managed to resolve this for my machines by adjusting the grub configuration like so:
In /etc/default/grub, change:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" to GRUB_CMDLINE_LINUX_DEFAULT="nomodeset" Then add this line:
GRUB_TERMINAL_INPUT="console serial" Run sudo update-grub and reboot for the changes to take effect.
Kyle
  • 90
Although I doesn't actually solve my problem, I managed to "bypass" it using another tty (Crtl-alt-F2) and now I can use my server
Ckubrak
  • 313
