Using Vinagre on Ubuntu 11.10, when I RDC into a remote Windows XP machine, I only get a 800x600 resolution on the remote display. I can't increase it on the Windows machine, it's stuck at 800x600. Any way to customise?
If I use Terminal Server Client on Ubuntu instead of Vinagre, I can adjust the res. Any way to fix for Vinagre?
nLinked
  • 3,387
I couldn't figure it out either. I'm now using remmina based on this post: http://www.jonathanmoeller.com/screed/?p=3411
remmina has more (or easier to find) settings, right when you set up the connection.
-Amir
Amir T
  • 380
A quick hack:
  1. mv /usr/bin/rdesktop /usr/bin/rdesktop.bin
  2. create the file /usr/bin/rdesktop to with the contents:
    #!/bin/bash
    /usr/bin/rdesktop.bin -g 1024x768 $*
  3. chmod 755 /usr/bin/rdesktop
The remote desktop viewer, vinagre, just runs rdesktop, so this in effect sets the default geometry.
joar
  • 567
Remmina → Vinagre, if only because it allows different RDP resolutions, and it includes a feature to import tsclient config files.
Peachy
  • 7,235
  • 40
  • 47
Kdt
