I recently updated to 15.10, and now when I boot up, It gets stuck on "Starting light display manager" part of the boot sequence.
I've purged and installed xorg, lightdm, nvidia drivers, all about a hundred times. I've also looked everywhere online looking for solutions, but no success.
I have an Nvidia GeForce 750 card, and I've tried installing almost all the drivers from either their site or from aptitude.
How can I debug/fix this?
Sgt. Pepper
  • 23
I have the same problem, but with an AMD card. I've found a work around by going into the console with
ctrl alt f1
sudo apt-get install xinit
then using the command
startx unity
I found a solution to the problem here Ubuntu 15.10 boot hangs when starting Lightdm
Reyn
  • 53
Sound support was disabled in the BIOS of the machine for me. Hence, no driver worked. This happened because I loaded the failsafe settings in the bios while trying to get the machine to boot via floppy, CD and USB. However, once I loaded the optimized defaults in the BIOS settings, everything worked fine.
