When i run tvtime,it gives me the following output in terminal:
Running tvtime 1.0.2.
Reading configuration from /etc/tvtime/tvtime.xml
Reading configuration from /home/md/.tvtime/tvtime.xml
xvoutput: No XVIDEO port found which supports YUY2 images.
*** tvtime requires hardware YUY2 overlay support from your video card
*** driver. If you are using an older NVIDIA card (TNT2), then
*** this capability is only available with their binary drivers.
*** For some ATI cards, this feature may be found in the experimental
*** GATOS drivers: http://gatos.souceforge.net/
*** If unsure, please check with your distribution to see if your
*** X driver supports hardware overlay surfaces.
Also i have intel 845gvsr motherboard and my tv tuner worked in past editions of ubuntu with this options saa7134 card=3 tuner=69 option putting inside /etc/modprobe.d/options file.
