Purchased a USB adapter( LinkSys AC1200 Wireless-AC USB adapter/ model WUSB6300) for my Windows laptop and the installation on that was easy. Tricky part is getting it to work in my Linux environment laptop. Cisco does not support Linux with this device.Need to figure out if I can install this to my Linux environment somehow. Some details:
Ubuntu:             14.04 LTS
lsusb:              Bus 002 Device 004: ID 13b1:003f Linksys
Hardware at Issue:  LinkSys AC1200 Wireless-AC USB adapter
model:              WUSB6300
Byte Commander
  • 110,243
ATXNOE
This can be done on a command line terminal:
This is a brand new device which needs a separate driver. Install it via LAN connection:
sudo apt-get install linux-headers-$(uname -r) linux-headers-generic build-essential git
git clone https://github.com/abperiasamy/rtl8812AU_8821AU_linux
cd rtl8812AU_8821AU_linux
make
sudo make install
Load the driver and check:
modinfo 8812au | egrep -i 'versi|filen|003f'
sudo modprobe -v 8812au
iwconfig
iwlist chan
Do not remove the driver folder. After a kernel update you need to compile again:
make clean
git fetch
git reset --hard origin/master
make
sudo make install
Be aware, that git fetch requires internet access to fetch driver updates from its source code repository, so you may want to do that before booting the new kernel.
(Source with some modifications)
David Foerster
  • 36,890
  • 56
  • 97
  • 151
