Hey:) I'm having a problem with an apple keyboard on my linux machine.
The less then / greater than key is swapped with my "°" key. The less than / greater than key is usually on the right side of shift as it shows on the keyboard.
Do you guys know the solution to this problem?
Seth
  • 59,332
roo1989
  • 41
(There must be perfect keyboard configuration files for your model/layout).
Anyway, The old way:
1 - find those keys:
$ xmodmap -pke | grep -Pw "degree|less" > mychanges
2 - edit "mychanges" to swap the keys. You probably have something like:
keycode 94 = less greater less greater bar brokenbar bar
keycode 49 = dead_circumflex degree dead_circumflex degree U2032 U2033 U2032
Swap the keys codes to:
keycode 49 = less greater less greater bar brokenbar bar
keycode 94 = dead_circumflex degree dead_circumflex degree U2032 U2033 U2032
3 - activate the changes with
xmodmap mychanges
4 - if your are happy with the new behaviour, do
cat mychanges >> ~/.Xmodmap
This approach can be used to generic keyboard changes (in graphic mode)
Select Apple Keyboard
I know this sounds silly, but there is actually an option in your Settings -> Keyboard that will get rid of this issue. You'll want to select an Apple/Mac keyboard.
Manually 'Select' Apple Keyboard at Boot
I used to use this method, until I realized the above method worked for me.
  • echo "0" > /sys/module/hid_apple/parameters/iso_layout
This will replace the content of the iso_layout file with the value 0
lauhub
  • 125
earthmeLon
  • 11,658
