I'm using Ubuntu 14.04 and have a Brother HL-2270DW printer that I am trying to connect to my computer via USB. I followed the instructions here to install the printer, and in general, it works fine. However, every time I get a software update, the printer uninstalls, and I have to re-run the installation script. Also, every time I get a software update, the printer settings in general reset (there are lots of WiFi connected printers around that I delete from my Printer Settings, only for them to all return when the update finishes). How can I keep this from continually happening every time something updates?
Thanks!
Edit:
Here's the output from the last time I ran sudo apt-get upgrade and had the printer go away:
sabeek@sabeek-S400CA:~$ sudo apt-get upgrade
[sudo] password for sabeek:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
cpio
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 73.3 kB of archives.
After this operation, 8,192 B disk space will be freed.
Do you want to continue? [Y/n] y
Get:1 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main cpio amd64 2.11+dfsg-1ubuntu1.1 [73.3 kB]
Fetched 73.3 kB in 0s (153 kB/s)
(Reading database ... 576043 files and directories currently installed.)
Preparing to unpack .../cpio_2.11+dfsg-1ubuntu1.1_amd64.deb ...
Unpacking cpio (2.11+dfsg-1ubuntu1.1) over (2.11+dfsg-1ubuntu1) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Setting up cpio (2.11+dfsg-1ubuntu1.1) ...
