After installing Ubuntu 14.04, the connection frequently drops. I tried to fix the problem by myself but I made things worse, I run this code I read in another article which made my connection really slow.
echo "options iwlwifi 11n_disable=1" | sudo tee /etc/modprobe.d/iwlwifi.conf
sudo modprobe -rfv iwlwifi
sudo modprobe -v iwlwifi
sudo iwconfig wlan0 power off
$ lspci -nn | grep 0280
07:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8188EE Wireless Network Adapter [10ec:8179] (rev 01)
Can you help me fix this?
A.B.
  • 92,125
You haven't an iwlwifi device or driver, so it is unlikely that iwlwifi 11n_disable=1 did anything. Please check here: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1310512 Notice it is your same 10ec:8179 device. Comment #30, it says:
Tips for RTL8188EE [10ec:8179] and RTL8723BE [10ec:b723] users: those hardware modules have MSI compatibility issue, on some certain platforms they work fine with MSI but break connections without MSI, on some other certain platforms it's opposite. You could try to toggle its module parameter "msi"
Let's try the driver parameter:
sudo -i
echo "options rtl8188ee msi=1"  >  /etc/modprobe.d/rtl8188ee.conf
exit
Reboot and tell us if stability is improved.
chili555
  • 61,330
Disabling the n-mode and updating only the kernel to 3.16 did the trick for me.
N-mode: echo "options iwlwifi 11n_disable=1" | sudo tee /etc/modprobe.d/iwlwifi.conf
Kernel update: How can I install 3.16 kernel on Ubuntu 14.04
Check to see if the problem persists when downloading a large file. If not, the problem might be http-request-side only, see https://askubuntu.com/a/147385/378854. You might have messed up your namespaces (resolv.conf).
Other than that, reinstalling the wifi driver might work:
sudo apt-get install --reinstall linux-headers-$(uname -r) linux-headers-generic build-essential dkms git
git clone https://github.com/pvaret/rtl8192cu-fixes.git
sudo dkms add ./rtl8192cu-fixes
sudo dkms install 8192cu/1.9
echo "blacklist rtl8192cu" | sudo tee -a /etc/modprobe.d/blacklist.conf
As of April 2016, the needed install cmd is 8192cu/1.10 (just check the latest version)
Or you might update your kernel manually to a newer version (not really difficult)
phil294
  • 639
