19
This one is correct:
$ find . -name *main.o
./main.o
So, why I can't find *.o?
$ find . -name *.o
find: paths must precede expression: main.o
Usage: find [-H] [-L] [-P] [-Olevel] [-D help|tree|search|stat|rates|opt|exec] [path...] [expression]
Eliah Kagan
  • 119,640
Student
  • 12,236
Probably there are more than one file that match *.o, while only one file match *main.o, so, in the first case, shell expansion runs:
$ find . -name main.o
and this works. In the second case:
$ find . -name file1.o main.o
And this is why you got error.
In order to prevent this, you should quote expression in both command:
$ find . -name '*.o'
$ find . -name '*main.o'
Lety
  • 6,089
  • 32
  • 38
16
Put the file pattern in quotes. Otherwise, * is expanded by the shell (resolved to a list of files before find sees it), confusing find.
find . -name "*.o"
