I have a Dell Inspiron 15R that came preinstalled with Windows 8.1 I just installed Ubuntu 12.04 in dual boot and got it working. Now i cannot connect to wifi. I tried How do I install BCM43142 wireless drivers for Dell Vostro 3460/3560? and also other methods involving installing firmware-b43-installer and b43-fwcutter. Nothing works. rfkill list all only shows Bluetooth:
rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
vipluv@Krishnakshetra:~$
My wireless hardware isn't detected at all! What do i do?
EDIT:
output for lspci -nnk | grep -iA2 net:
    01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 07)
        Subsystem: Dell Device [1028:05e9]
        Kernel driver in use: r8169
02:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
    Subsystem: Dell Wireless 1704 802.11n + BT 4.0 [1028:0016]
    Kernel driver in use: bcma-pci-bridge
and for iwconfig:
eth0      no wireless extensions.
lo        no wireless extensions.
Step one: Connect your system to the network temporarily using an Ethernet cable.
Step two: Open a terminal and issue the commands: sudo apt-get update and then after that completes, sudo apt-get upgrade
Step three:
Open Additional Drivers and install what is recommended. If there aren't any needed or recommended you'll see this:
additionaldrivers
If your wireless hardware isn't detected at all, consider trying a USB wifi adapter as the integrated one may be damaged somehow.
Elder Geek
  • 36,752
