I previously setup my mail server using Ubuntu 12.04LTS and all worked fine (see Postfix Dovecot SASL Authentication not enabled/working ubuntu 12.04 server), but I recently moved everything to new server and upgrade to Ubuntu 14.04 LTS and I lost something in the Dovecot SASL configuration because I can't Authenticate using Dovecot SASL ... I get the following error
Jun 12 05:15:30 example dovecot: auth: Error: pgsql(192.168.1.11:3145): Connect failed to database mwdmail: could not translate host name "192.168.1.11:3145" to address: Name or service not known
Jun 12 05:16:31 example dovecot: auth: Error: pgsql: Query timed out (no free connections for 61 secs): SELECT username as user, password, '/mwdmail/mbox/example.com/cmadm' as userdb_home, 'maildir:/mwdmail/mbox/example.com/cmadm' as userdb_mail, 3205 as userdb_uid, 3205 as userdb_gid FROM mailbox WHERE username='cmadm@example.com' AND active = true;
Jun 12 05:16:31 example dovecot: auth: Error: sql(cmadm@example.com,127.0.0.1,<tYikAKD74gB/AAAB>): Password query failed: Not connected to database
Jun 12 05:17:44 example dovecot: auth: Error: pgsql(192.168.1.11:3145): Connect failed to database mwdmail: could not translate host name "192.168.1.11:3145" to address: Name or service not known
postconf -n (main.cf file)
    alias_database = hash:/etc/aliases
    alias_maps = hash:/etc/aliases
    append_dot_mydomain = no
    biff = no
    broken_sasl_auth_clients = yes
    command_directory = /usr/sbin
    config_directory = /etc/postfix
    content_filter = amavis:[127.0.0.1]:10024
    daemon_directory = /usr/libexec/postfix
    data_directory = /var/lib/postfix
    disable_vrfy_command = yes
    dovecot_destination_recipient_limit = 1
    enable_original_recipient = no
    header_checks = regexp:/etc/postfix/header_checks
    inet_interfaces = all
    inet_protocols = ipv4
    local_recipient_maps = $virtual_mailbox_maps
    local_transport = virtual
    mail_owner = mwdpost
    mailbox_size_limit = 0
    mailq_path = /usr/bin/mailq
    manpage_directory = /usr/local/man
    mydestination = example.com, localhost.com, localhost
    mydomain = example.com
    myhostname = example.com
    mynetworks = 192.168.1.0/24, 127.0.0.0/8
    mynetworks_style = host
    myorigin = $mydomain
    newaliases_path = /usr/bin/newaliases
    queue_directory = /var/spool/postfix
    readme_directory = no
    recipient_delimiter = +
    relay_domains = proxy:pgsql:/etc/postfix/pgsql/relay_domains.cf
    relayhost =
    setgid_group = mwdpdrop
    smtp_tls_security_level = may
    smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
    smtp_use_tls = yes
    smtpd_banner = $myhostname ESMTP $mail_name
    smtpd_client_restrictions = permit_sasl_authenticated, reject_rbl_client zen.spamhaus.org, reject_rbl_client sbl.spamhaus.org, reject_rbl_client blackholes.easynet.nl
    smtpd_delay_reject = yes
    smtpd_helo_required = yes
    smtpd_relay_restrictions = reject_sender_login_mismatch, permit_sasl_authenticated, permit_mynetworks, reject_unauth_destination
    smtpd_sasl_auth_enable = yes
    smtpd_sasl_authenticated_header = yes
    smtpd_sasl_local_domain = $myhostname
    smtpd_sasl_path = private/auth
    smtpd_sasl_security_options = noanonymous
    smtpd_sasl_tls_security_options = noanonymous
    smtpd_sasl_type = dovecot
    smtpd_sender_login_maps = hash:/etc/postfix/sasl/controlled_envelope_senders
    smtpd_sender_restrictions = permit_sasl_authenticated, reject_unknown_sender_domain, permit_mynetworks
    smtpd_tls_auth_only = no
    smtpd_tls_cert_file = /etc/ssl/certs/ssl-mail.pem
    smtpd_tls_key_file = /etc/ssl/private/ssl-mail.key
    smtpd_tls_loglevel = 1
    smtpd_tls_mandatory_ciphers = medium
    smtpd_tls_mandatory_protocols = SSLv3, TLSv1
    smtpd_tls_received_header = yes
    smtpd_tls_security_level = may
    smtpd_tls_session_cache_timeout = 3600s
    smtpd_use_tls = yes
    tls_random_source = dev:/dev/urandom
    virtual_alias_maps = proxy:pgsql:/etc/postfix/pgsql/virtual_alias_map.cf
    virtual_gid_maps = static:3205
    virtual_mailbox_base = /mwdmail/mbox
    virtual_mailbox_domains = proxy:pgsql:/etc/postfix/pgsql/virtual_domain_map.cf
    virtual_mailbox_limit = 512000000
    virtual_mailbox_maps = proxy:pgsql:/etc/postfix/pgsql/virtual_mailbox_map.cf
    virtual_minimum_uid = 3205
    virtual_transport = lmtp:unix:private/dovecot-lmtp
    virtual_uid_maps = static:3205
postconf -M (master.cf file)
#SMTP on port 25, unencrypted.
smtp      inet  n       -       -       -       -       smtpd -v
smtpd     pass  -       -       -       -       -       smtpd -v
# SMTP with TLS on port 587.
submission inet n - - - - smtpd -v
  -o smtpd_tls_security_level=encrypt
  -o smtpd_sasl_auth_enable=yes
  -o smtpd_sasl_type=dovecot
  -o smtpd_sasl_path=private/auth
  -o smtpd_sasl_security_options=noanonymous
  -o smtpd_sasl_local_domain=$myhostname
  -o smtpd_client_restrictions=permit_sasl_authenticated,reject
  -o smtpd_sender_login_maps=hash:/etc/postfix/sasl/controlled_envelope_senders
# -o smtpd_sender_login_maps=hash:/etc/postfix/virtual
  -o smtpd_sender_restrictions=reject_sender_login_mismatch
  -o smtpd_recipient_restrictions=reject_non_fqdn_recipient,reject_unknown_recipient_domain,permit_sasl_authenticated,reject
# SMTP over SSL on port 465.
smtps     inet  n       -       -       -       -       smtpd -v
  -o syslog_name=postfix/smtps
  -o smtpd_tls_wrappermode=yes
  -o smtpd_tls_auth_only=yes
  -o smtpd_client_restrictions=permit_sasl_authenticated,reject_unauth_destination,reject
  -o smtpd_sasl_security_options=noanonymous,noplaintext
  -o smtpd_sasl_tls_security_options=noanonymous
#628       inet  n       -       -       -       -       qmqpd
pickup    fifo  n       -       -       60      1       pickup
  -o content_filter=
  -o receive_override_options=no_header_body_checks
cleanup   unix  n       -       -       -       0       cleanup
qmgr      fifo  n       -       n       300     1       qmgr
#qmgr     fifo  n       -       n       300     1       oqmgr
tlsmgr    unix  -       -       -       1000?   1       tlsmgr
rewrite   unix  -       -       -       -       -       trivial-rewrite
bounce    unix  -       -       -       -       0       bounce
defer     unix  -       -       -       -       0       bounce
trace     unix  -       -       -       -       0       bounce
verify    unix  -       -       -       -       1       verify
flush     unix  n       -       -       1000?   0       flush
proxymap  unix  -       -       n       -       -       proxymap
proxywrite unix -       -       n       -       1       proxymap
smtp      unix  -       -       -       -       -       smtp
relay     unix  -       -       -       -       -       smtp
#       -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq     unix  n       -       -       -       -       showq
error     unix  -       -       -       -       -       error
retry     unix  -       -       -       -       -       error
discard   unix  -       -       -       -       -       discard
local     unix  -       n       n       -       -       local
virtual   unix  -       n       n       -       -       virtual
lmtp      unix  -       -       -       -       -       lmtp
anvil     unix  -       -       -       -       1       anvil
scache    unix  -       -       -       -       1       scache
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
dovecot   unix  -       n       n       -       -       pipe
  flags=DRhu user=mwdvm:mwdvm argv=/usr/bin/vendor_perl/spamc -f -e /usr/lib/dovecot/deliver -f ${sender} -d ${recipient}
uucp      unix  -       n       n       -       -       pipe
  flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
ifmail    unix  -       n       n       -       -       pipe
  flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp     unix  -       n       n       -       -       pipe
  flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix  -       n       n       -       2       pipe
  flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman   unix  -       n       n       -       -       pipe
  flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
  ${nexthop} ${user}
# The next two entries integrate with Amavis for anti-virus/spam checks.
amavis      unix    -       -       -       -       3       smtp
  -o smtp_data_done_timeout=1200
  -o smtp_send_xforward_command=yes
  -o disable_dns_lookups=yes
  -o max_use=20
127.0.0.1:10025 inet    n       -       -       -       -       smtpd
  -o content_filter=
  -o local_recipient_maps=
  -o relay_recipient_maps=
  -o smtpd_restriction_classes=
  -o smtpd_delay_reject=no
  -o smtpd_client_restrictions=permit_mynetworks,reject
  -o smtpd_helo_restrictions=
  -o smtpd_recipient_restrictions=permit_mynetworks,reject
 -o smtpd_data_restrictions=reject_unauth_pipelining
  -o smtpd_end_of_data_restrictions=
  -o mynetworks=192.168.1.0/32,127.0.0.0/8
#  -o mynetworks=0.0.0.0
  -o smtpd_error_sleep_time=0
  -o smtpd_soft_error_limit=1001
  -o smtpd_hard_error_limit=1000
  -o smtpd_client_connection_count_limit=0
  -o smtpd_client_connection_rate_limit=0
  -o receive_override_options=no_header_body_checks,no_unknown_recipient_checks
# Integration with Dovecot - hand mail over to it for local delivery, and
# run the process under the vmail user and mail group.
  flags=DRhu user=mwdvm:mwdvm argv=/usr/lib/dovecot/dovecot-lda -d $(recipient)
SASL AUTHENTICATION is enabled per telnet check
root@example:~# telnet 192.168.1.11 25
Trying 192.168.1.11...
Connected to 192.168.1.11.
Escape character is '^]'.
220 example.com ESMTP Postfix
ehlo example.com
250-example.com
250-PIPELINING
250-SIZE 10240000
250-ETRN
250-STARTTLS
250-AUTH PLAIN LOGIN
250-AUTH=PLAIN LOGIN
250-ENHANCEDSTATUSCODES
250-8BITMIME
250 DSN
doveconf -n
# 2.2.9: /etc/dovecot/dovecot.conf
# OS: Linux 3.13.0-29-generic x86_64 Ubuntu 14.04 LTS
auth_debug = yes
auth_debug_passwords = yes
auth_mechanisms = plain login
auth_verbose = yes
first_valid_uid = 3205
last_valid_uid = 3205
mail_gid = mwdvm
mail_location = maildir:~/Maildir
mail_uid = mwdvm
managesieve_notify_capability = mailto
managesieve_sieve_capability = fileinto reject envelope encoded-character vacation subaddress comparator-i;ascii-numeric relational regex imap4flags copy include variables body enotify environment mailbox date ihave
namespace inbox {
  location =
  mailbox Drafts {
    special_use = \Drafts
  mailbox Junk {
    special_use = \Junk
  mailbox Sent {
    special_use = \Sent
  mailbox "Sent Messages" {
    special_use = \Sent
  mailbox Trash {
    special_use = \Trash
  prefix =
passdb {
  args = /etc/dovecot/dovecot-sql.conf.ext
  driver = sql
plugin {
  sieve = ~/.dovecot.sieve
  sieve_dir = ~/sieve
postmaster_address = postmaster@example.com
protocols = imap pop3 sieve
service auth-worker {
  user = $default_internal_user
service auth {
  unix_listener /var/spool/postfix/private/auth {
    group = mwdpost
    mode = 0660
    user = mwdpost
  unix_listener /var/spool/postfix/private/dovecot-auth {
    #group = postfix
    group = mwdpost
    mode = 0660
    #user = postfix
    user = mwdpost
  unix_listener auth-userdb {
    group = mwdvm
    mode = 0600
    user = mwdvm
  user = dovecot
service lmtp {
  unix_listener /var/spool/postfix/private/dovecot-lmtp {
    group = mwdpost
    mode = 0600
    user = mwdpost
ssl_cert = </etc/dovecot/dovecot.pem
ssl_cipher_list = ALL:!LOW:!SSLv2:ALL:!aNULL:!ADH:!eNULL:!EXP:RC4+RSA:+HIGH:+MEDIUM
ssl_key = </etc/dovecot/private/dovecot.pem
userdb {
  driver = sql
protocol imap {
  imap_client_workarounds = delay-newmail
  mail_max_userip_connections = 10
protocol pop3 {
  pop3_client_workarounds = outlook-no-nuls oe-ns-eoh
protocol lda {
  auth_socket_path = /var/run/dovecot/auth-master
  deliver_log_format = msgid=%m: %$
  log_path = /var/log/dovecot-lda.log
  mail_plugins = sieve
  quota_full_tempfail = yes
  rejection_reason = Your message to <%t> was automatically rejected:%n%r
dovecot authentication file:
# This file is opened as root, so it should be owned by root and mode 0600.
# http://wiki2.dovecot.org/AuthDatabase/SQL
# For the sql passdb module, you'll need a database with a table that
# contains fields for at least the username and password. If you want to
# use the user@domain syntax, you might want to have a separate domain
# field as well.
# If your users all have the same uig/gid, and have predictable home
# directories, you can use the static userdb module to generate the home
# dir based on the username and domain. In this case, you won't need fields
# for home, uid, or gid in the database.
# If you prefer to use the sql userdb module, you'll want to add fields
# for home, uid, and gid. Here is an example table:
# CREATE TABLE users (
#     username VARCHAR(128) NOT NULL,
#     domain VARCHAR(128) NOT NULL,
#     password VARCHAR(64) NOT NULL,
#     home VARCHAR(255) NOT NULL,
#     uid INTEGER NOT NULL,
#     gid INTEGER NOT NULL,
#     active CHAR(1) DEFAULT 'Y' NOT NULL
# Database driver: mysql, pgsql, sqlite
#driver =
driver = pgsql
# Database connection string. This is driver-specific setting.
# HA / round-robin load-balancing is supported by giving multiple host
# settings, like: host=sql1.host.org host=sql2.host.org
# pgsql:
#   For available options, see the PostgreSQL documention for the
#   PQconnectdb function of libpq.
#   Use maxconns=n (default 5) to change how many connections Dovecot can
#   create to pgsql.
# mysql:
#   Basic options emulate PostgreSQL option names:
#     host, port, user, password, dbname
#   But also adds some new settings:
#     client_flags        - See MySQL manual
#     ssl_ca, ssl_ca_path - Set either one or both to enable SSL
#     ssl_cert, ssl_key   - For sending client-side certificates to server
#     ssl_cipher          - Set minimum allowed cipher security (default: HIGH)
#     option_file         - Read options from the given file instead of
#                           the default my.cnf location
#     option_group        - Read options from the given group (default: client)
#   You can connect to UNIX sockets by using host: host=/var/run/mysql.sock
#   Note that currently you can't use spaces in parameters.
# sqlite:
#   The path to the database file.
# Examples:
#   connect = host=192.168.1.1 dbname=users
#   connect = host=sql.example.com dbname=virtual user=virtual password=blarg
#   connect = /etc/dovecot/authdb.sqlite
#connect =
connect = host=192.168.1.11:3145 dbname=mwdmail user=mwdmlusr password=t1mim@1l
# Default password scheme.
# List of supported schemes is in
# http://wiki2.dovecot.org/Authentication/PasswordSchemes
#default_pass_scheme = MD5
default_pass_scheme = SHA516-CRYPT
# passdb query to retrieve the password. It can return fields:
#   password - The user's password. This field must be returned.
#   user - user@domain from the database. Needed with case-insensitive lookups.
#   username and domain - An alternative way to represent the "user" field.
# The "user" field is often necessary with case-insensitive lookups to avoid
# e.g. "name" and "nAme" logins creating two different mail directories. If
# your user and domain names are in separate fields, you can return "username"
# and "domain" fields instead of "user".
# The query can also return other fields which have a special meaning, see
# http://wiki2.dovecot.org/PasswordDatabase/ExtraFields
# Commonly used available substitutions (see http://wiki2.dovecot.org/Variables
# for full list):
#   %u = entire user@domain
#   %n = user part of user@domain
#   %d = domain part of user@domain
# Note that these can be used only as input to SQL query. If the query outputs
# any of these substitutions, they're not touched. Otherwise it would be
# difficult to have eg. usernames containing '%' characters.
# Example:
#   password_query = SELECT userid AS user, pw AS password \
#     FROM users WHERE userid = '%u' AND active = 'Y'
#password_query = \
#  SELECT username, domain, password \
#  FROM users WHERE username = '%n' AND domain = '%d'
password_query = \
SELECT username as user, password, '/mwdmail/mbox/%d/%n' as userdb_home, 'maildir:/mwdmail/mbox/%d/%n' as userdb_mail, 3205 as userdb_uid, 3205 as userdb_gid \
FROM mailbox WHERE username='%u' AND active = true;
# userdb query to retrieve the user information. It can return fields:
#   uid - System UID (overrides mail_uid setting)
#   gid - System GID (overrides mail_gid setting)
#   home - Home directory
#   mail - Mail location (overrides mail_location setting)
# None of these are strictly required. If you use a single UID and GID, and
# home or mail directory fits to a template string, you could use userdb static
# instead. For a list of all fields that can be returned, see
# http://wiki2.dovecot.org/UserDatabase/ExtraFields
# Examples:
#   user_query = SELECT home, uid, gid FROM users WHERE userid = '%u'
#   user_query = SELECT dir AS home, user AS uid, group AS gid FROM users where userid = '%u'
#   user_query = SELECT home, 501 AS uid, 501 AS gid FROM users WHERE userid = '%u'
#user_query = \
#  SELECT home, uid, gid \
user_query = \
SELECT '/mwdmail/mbox/%d/%n' as home, 'maildir:/mwdmail/mbox/%d/%n' as mail, 3205 AS uid, 3205 AS gid, 'dirsize:storage=' ||  quota AS quota FROM mailbox WHERE username = '%u' AND active = true
# If you wish to avoid two SQL lookups (passdb + userdb), you can use
# userdb prefetch instead of userdb sql in dovecot.conf. In that case you'll
# also have to return userdb fields in password_query prefixed with "userdb_"
# string. For example:
#password_query = \
#  SELECT userid AS user, password, \
#    home AS userdb_home, uid AS userdb_uid, gid AS userdb_gid \
# Query to get a list of all usernames.
#iterate_query = SELECT username AS user FROM users
I can do the following:
  • send email to external address from commandline root account
  • Send email to local and virtual mailboxes from commandline root account
  • Receive email to a virtual mailbox from external email accounts *
I can NOT do the following:
  • Receive email to a virtual mailbox from external email accounts (*THIS IS FIXED)
  • Log into a virtual mailbox from a remote client like thunderbird or roundcube
I know there must be some configuration I missing or mixing up. Please help. Thanks
* **UPDATED *** 6/13/2014 ******* Per @clement, I updated the post with the files and while doing dovecot -n. I noticed I had the wrong userid/groupid in file /etc/dovecot/conf.d/99-mail-stack-delivery.conf.ext corrected it and then the error went away . I also can receive email from external accounts, but I get a new error and when I try to connect through thunderbird or roundcube the same error (posted above appears)
New error (from syslog)
Jun 13 12:48:59 example amavis[1636]: (01636-01) Connecting to SQL database server
Jun 13 12:48:59 example amavis[1636]: (01636-01) connect_to_sql: 'DBI:Pg:database=mwdmail;host=192.168.1.11;port=3145' succeeded
Jun 13 12:48:59 example amavis[1636]: (01636-01) ESMTP::10024 /var/lib/amavis/tmp/amavis-20140613T124859-01636-8zgfTr8G: <myemailid@gmail.com> -> <cmadm@example.com> SIZE=1994 Received: from example.com ([127.0.0.1]) by localhost (example.com [127.0.0.1]) (amavisd-new, port 10024) with ESMTP for <cmadm@example.com>; Fri, 13 Jun 2014 12:48:59 -0400 (EDT)
Jun 13 12:48:59 example amavis[1636]: (01636-01) body hash: 3c1b1ba2edc70e49703dfd1f314cbf88
Jun 13 12:48:59 example amavis[1636]: (01636-01) dkim: FAILED Author+Sender+MailFrom signature by d=gmail.com, From: <myemailid@gmail.com>, a=rsa-sha256, c=relaxed/relaxed, s=20120113, i=@gmail.com, fail (message has been altered)
Jun 13 12:48:59 example amavis[1636]: (01636-01) Checking: ir664hlqxaJx [209.85.128.170] <myemailid@gmail.com> -> <cmadm@example.com>
Jun 13 12:48:59 example amavis[1636]: (01636-01) 2822.From: <myemailid@gmail.com>
Jun 13 12:48:59 example amavis[1636]: (01636-01) p001 1 Content-Type: text/plain, size: 769 B, name:
Jun 13 12:49:00 example amavis[1636]: (01636-01) Checking for banned types and filenames
Jun 13 12:49:00 example amavis[1636]: (01636-01) collect banned table[0]: cmadm@example.com, tables: DEFAULT=>Amavis::Lookup::RE=ARRAY(0x2541dc0)
Jun 13 12:49:00 example amavis[1636]: (01636-01) p.path cmadm@example.com: "P=p001,L=1,M=text/plain,T=asc"
Jun 13 12:49:00 example amavis[1636]: (01636-01) run_av Using (ClamAV-clamd): (code) CONTSCAN /var/lib/amavis/tmp/amavis-20140613T124859-01636-8zgfTr8G/parts\n
Jun 13 12:49:00 example amavis[1636]: (01636-01) ClamAV-clamd: Connecting to socket  /var/run/clamav/clamd.ctl
Jun 13 12:49:00 example amavis[1636]: (01636-01) new socket by IO::Socket::UNIX to /var/run/clamav/clamd.ctl, timeout 10
Jun 13 12:49:00 example amavis[1636]: (01636-01) ClamAV-clamd: Sending CONTSCAN /var/lib/amavis/tmp/amavis-20140613T124859-01636-8zgfTr8G/parts\n to socket /var/run/clamav/clamd.ctl
Jun 13 12:49:00 example amavis[1636]: (01636-01) rw_loop read: got eof
Jun 13 12:49:00 example amavis[1636]: (01636-01) run_av (ClamAV-clamd): CLEAN
Jun 13 12:49:00 example amavis[1636]: (01636-01) run_av (ClamAV-clamd) result: clean
cmweb
  • 45
@clement ..this is resolved. I reinstalled everything again and carefully updated all my postfix and dovecot files. I had a few typos and the new User ID and Group ID I created for postfix and postdrop did not have the correct permissions everywhere. I have another issue but will report that on another post.
Thank you.
cmweb
  • 45
