I'm running Ubuntu 12.04. I installed xscreensaver in place of gnome.screensaver.
My problem is that I cannot get the screensaver to stop popping up when I'm watching a movie on Movie Player. I have Movie Player set to disable screensavers but it's not working on xscreensaver.
How do I change the program files to disable xscreensaver while Movie Player is running?
user.dz
  • 49,176
6 Answers6
You may try similar script to this one. Watch for player state through DBUS.
I lower delay to 55 sec, work better with 1min screen saver idle time.
  • Example VLC:
    BTW, VLC in Ubuntu 14.04 has DBUS interface enabled by default. Where in Ubuntu 12.04 is not. Check it from:
    Tools → Preferences → Advanced (or All) → Interface → Control Interfaces → D-Bus control interface. (Apply then Restart VLC)
    1. Create a file heartbeat.sh in ~/Desktop/:
      #!/bin/bash
      while sleep 55
      do
          if [ "$(pgrep vlc)" != "" ]
          then
              state=$(bash -c 'gdbus call --session \
                  --dest org.mpris.MediaPlayer2.vlc \
                  --object-path /org/mpris/MediaPlayer2 \
                  --method org.freedesktop.DBus.Properties.Get \
                  "org.mpris.MediaPlayer2.Player" \
                  "PlaybackStatus"')
              if [ "$state" = "(<'Playing'>,)" ]
              then
                  #xscreensaver-command -deactivate
                  xset s reset
              fi
          fi
      done
    2. Open terminal Ctrl+Alt+t
    3. Add run permissions:
      chmod +x ~/Desktop/heartbeat.sh
    4. Run script:
    5. Try VLC player.
  • For Gnome MPlayer (D-Bus enabled by default), use:
    "$(pgrep gnome-mplayer)" and --dest org.mpris.MediaPlayer2.gnome-mplayer
  • For (Totem) Videos player (D-Bus plugin disabled by default),
    Edit → Plugins → Check D-Bus service. (Restart totem)
    Use:
    "$(pgrep totem)" and --dest org.mpris.MediaPlayer2.totem
  • This is modified with to work with any player that provide MPRIS. It gets the list dynamically (drawback, it doesn't distinguish between audio only play and video play). The best way I think is to put manually the list of players you like:
    #!/bin/bash
    players_list=$(gdbus call --session --dest org.freedesktop.DBus \
        --object-path / --method org.freedesktop.DBus.ListNames | \
        awk 'BEGIN { RS=","; } /org.mpris.MediaPlayer2./ { gsub(/[\[\]()\x27]/, ""); print $1; }')
    while sleep 55
    do
        for player in $players_list
        do
            state=$(gdbus call --session \
                --dest $player \
                "PlaybackStatus")
            then
                echo $player $state send signal
                #use xset to work with all screensaver tools and avoid dimming display ...
                xset s reset
                break
            else
                echo $player $state
            fi
        done
    done
Debug hints:
  1. Watch X idle time
    watch -n1 xprintidle
    or:
    while sleep 1; do xprintidle; done;
  2. Check if disabling screensaver works (while running this script, xscreensave should not pop up)
        #!/bin/bash
        while sleep 55
        do
            #xdg-screensaver reset
            xset s reset
        done
  3. Check for DBUS list for MPRIS player interface, example with VLC running:
    Output:
        org.mpris.MediaPlayer2.vlc.instance3939
    Or using dbus-send command
        dbus-send --session \
        --dest=org.freedesktop.DBus \
        --type=method_call \
        --print-reply \
        /org/freedesktop/DBus \
        org.freedesktop.DBus.ListNames \
        | grep org.mpris.MediaPlayer2.
    Output:
        string "org.mpris.MediaPlayer2.vlc"
        string "org.mpris.MediaPlayer2.vlc.instance3939"
References:
user.dz
  • 49,176
For MPV, and mplayer, the heartbeat functionality is built in.
1) Locate your mpv configuration file. locate mpv.conf
2) Open it up. sudo nano /path/to/mpv.conf
3) Add this line at the bottom. heartbeat-cmd="/usr/bin/xscreensaver-command -deactivate > /dev/null"
4) Close, and save. Ctrl+X if using nano.
Find out where to find your mpv.conf file here (configuration is identical on Arch Linux), https://wiki.archlinux.org/index.php/Mpv#Configuration
If the environment variable XDG_CONFIG_HOME is not set, user configuration files will be read from the ~/.config/mpv directory. System-wide configuration files are read from the /etc/mpv directory.
I noticed all the answers here seemed unnecessarily complex; you don't really need to do this based on a specific media player - all you need to do is detect if any audio is playing. I'm actually surprised this isn't a feature built into xscreensaver. Here's a super simple bash script:
#!/bin/bash
while true
do
    state=$(pacmd list-sinks | grep -A 4 "*" | grep "state: " | cut -c 9-)
    if [[ $state == SUSPENDED || $state == IDLE ]]
    then
        echo "State: $state. Not pausing screensaver."
        sleep 2m
    else
        echo "State: $state. Pausing screensaver."
        sleep 4m
    fi
done
derHugo
  • 3,376
  • 34
  • 52
This worked for me with Xubuntu 18.10 and with VLC, youtube videos, etc... wiithout the need to disable xscreensaver. Just add the following script when you system start:
#!/bin/bash
# enumerate all the attached screens
displays=""
while read id
do
    displays="$displays $id"
done< <(xvinfo | sed -n 's/^screen #\([0-9]\+\)$/\1/p')
checkFullscreen() {
# loop through every display looking for a fullscreen window
for display in $displays
do
    #get id of active window and clean output
    activ_win_id=`DISPLAY=:0.${display} xprop -root _NET_ACTIVE_WINDOW`
    activ_win_id=${activ_win_id:40:9}
    # Check if Active Window (the foremost window) is in fullscreen state
    isActivWinFullscreen=`DISPLAY=:0.${display} xprop -id $activ_win_id | grep _NET_WM_STATE_FULLSCREEN`
    if [[ &quot;$isActivWinFullscreen&quot; == *NET_WM_STATE_FULLSCREEN* ]];then
    fi
done
while sleep $((30)); do checkFullscreen done
exit 0
Alter Lagos
  • 1,209
Here is my own version from Chris' code:
#!/bin/bash
while sleep 55
do
    do
            --dest $player \
            "PlaybackStatus")
        fullscreen=$(gdbus call --session \
            --dest $player \
            "org.mpris.MediaPlayer2" \
            "Fullscreen")
        if [ "$state" = "(<'Playing'>,)" -a "$fullscreen" = "(<true>,)" ]
        then
            echo $player $state $fullscreen send signal
            break
        else
        fi
    done
done
It checks at each iteration if the list of players has been changed.
It also deactivates the screensaver only if the player is fullscreen which is normally the case for video.
I just put this script in the autostart and don't bother anymore with xscreensaver while watching video.
derHugo
  • 3,376
  • 34
  • 52
sk3
This worked for me on Xubuntu 17.10 with xscreensaver
#!/bin/bash
while true; do
    sleep 10
    cat /proc/asound/card*/pcm*/sub*/status | grep RUNNING && xscreensaver-command -deactivate
done
nmz787
  • 131
