I am having problems installing my canon mp620 wireless printer. The system sees the printer but when I try to print a test page it only adds to the print cue without completing the task.
Asked
Active
Viewed 1,473 times
I had the same problem with the Canon MP620 (on Ubuntu 13.10 and 14.04) and fixed it by following the advice here.
One of the posts suggests using BJNP, a protocol used by Canon printers. Following this advice, I tried adding the printer using the device URI: "bjnp://xxx.xxx.xx.xxx:8611", where 'xxx.xxx.xx.xxx' is the printer IP address.
You may have to make an exception for the relevant port in UFW to get the scanner to work, in this case:
sudo ufw allow 8611
After that I found both printing and scanning work flawlessly.
Hope that helps.
Eric Carvalho
- 55,453
Tim
- 1
