I have a 3-4 years old laptop (Compaq V3000), which had Win Vista with Ubuntu 10.10 in dual boot configuration. The graphics card inside is an old Nvidia GeForce Go 7200.
One fine day, my graphics card died (of old age, presumably) - resulting in myself being initially unable to boot to WinVista and Ubuntu 10.10. I solved the problem with WinVista (disabled Nvidia card after booting to Safe mode), but I don't know how to do the same with Ubuntu. I can only disable the 3rd-party driver after I boot to desktop, but since its crashing before that, I'm unable to do so.
Can anyone help me disable the graphics card in Ubuntu?
htorque
  • 66,086
TCSGrad
  • 223
Looks like you've issues with your initial ramdisk (initrd) which expects your nVidia card. You'll need to update this initrd.
Boot with a LiveCD and follow the next steps:
  1. Mount your Ubuntu root partition, change XY accordingly:
    sudo mount /dev/sdXY /mnt
  2. Mount some partitions:
    sudo mount --bind /dev /mnt/dev
    sudo mount --bind /proc /mnt/proc
    sudo mount --bind /sys /mnt/sys
  3. Change your root directory to the mounted Ubuntu partition:
    sudo chroot /mnt
  4. You'll end up in a root shell, now update the initial ramdisk (this may take a few seconds):
    update-initramfs -u
  5. Now you're finished, exit from the chroot and unmount some filesystems:
    exit
    sudo umount /mnt/{sys,proc,dev} /mnt
  6. Reboot.
Lekensteyn
  • 178,446
I've had this situation happen to me recently except on my case the proprietary drivers wouldn't play nice with my nvidia gt 220 card and so I need to disable it, booting normally crashes the boot process.
So tried to boot using the recovery console, got to the terminal as root and then just did
apt-get remove nvidia-current
Rebooted and then logged in and enabled the nouveau driver. So far everything is working now with compiz.
