here is intel-core-i-7 with 2.8 Ghz resp. 3.5 Ghz as turbo-boost option.
with this question I refer to this link:
Does Intel turbo boost work in Ubuntu?
Is option of turbo-boost not harming the hardware regarding the life-time of the processor resp. of the hard-ware ?
I know by benchmarking of hard-disks - like defragmenting under windows - that such benchmarking can shorten the life-time of hardware up to 3 times ... ( my harddisk of the first PC in 2000 under windows - was broken by win98SE after only 2 years ).
when should I use turbo-boost resp. when should I avoid it ?
dschinn1001
  • 3,863
turbo doesn't harm your computer, can you find any evidence of this?
Turbo overclocks the cpu for a short period of time, so if you have bad cpu cooler it may have negative effect, but then a bad cpu cooler should be replaced. You should always use turbo unless the temperature of the CPU is too high (near it's max value).
Also hard drives have improved a lot since Windows 98 was released. Also defragmentation and performance test aren't the same, defragmentation moves around the files and performance test maxes the hard drive out.
Alvar
  • 17,038
