My laptop is Dell Inspiron N4050. Now I am using Jupiter. While using Ubuntu it shows the CPU temperature is between 45°C - 65°C. Is it okay for my laptop? Mine CPU temperature is between 48°C-55°C most of the time. As I mentioned 45°C is the minimum and 65°C is the Maximum. Is it okay for my Laptop? What do you say, should I stop worrying?
Asked
Active
Viewed 2,491 times
According to Dell your laptop can have 3 different processors. These processors are listed below with their max temperatures.
According to Intel:
If you have Intel Pentium Processor B950 (2M Cache, 2.10 GHz) the maximum temperature allowed at the processor die is 85°C
If you have Intel Core i5-2430M Processor (3M Cache, up to 3.00 GHz) the maximum temperature allowed at the processor die is 100°C
If you have Intel Core i3-2330M Processor (3M Cache, 2.20 GHz) the maximum temperature allowed at the processor die is 85°C - 100°C
So by that since your is between 45°C - 65°C you should be OK.
As per your comment, that you have Intel Core i3-2350M CPU @ 2.30GHz, just see images below:
Mitch
- 109,787
