I am using Ubuntu 10.10 (Linux pc07 2.6.35-27-generic #48-Ubuntu SMP Tue Feb 22 20:25:46 UTC 2011 x86_64 GNU/Linux) and the default python package (Python 2.6.6).
I would like to install python-psyco to improve the performance of one of my scripts, but only python-psyco-doc is available for 64 bit.
I tried a virtual machine, but the the performance boost is much less on the virtual machine than on a "real" installed 32-bit Ubuntu.
So my question is: How can I install a 32Bit Python with psyco on my 64Bit Ubuntu machine?
edit: I've found this article and made this:
- Download "Python 2.7.1 bzipped source tarball" from http://python.org/download/
- Go in the directory where you decompressed "Python 2.7.1"
OPT=-m32 LDFLAGS=-m32 ./configure --prefix=/opt/pym32make
But I got this error:
gcc -pthread -m32 -Xlinker -export-dynamic -o python \
Modules/python.o \
libpython2.7.a -lpthread -ldl -lutil -lm
libpython2.7.a(posixmodule.o): In function `posix_tmpnam':
/home/moose/Downloads/Python-2.7.1/./Modules/posixmodule.c:7346: warning: the use of `tmpnam_r' is dangerous, better use `mkstemp'
libpython2.7.a(posixmodule.o): In function `posix_tempnam':
/home/moose/Downloads/Python-2.7.1/./Modules/posixmodule.c:7301: warning: the use of `tempnam' is dangerous, better use `mkstemp'
Segmentation fault
make: *** [sharedmods] Fehler 139
edit2: Now I've found http://indefinitestudies.org/2010/02/08/how-to-build-32-bit-python-on-ubuntu-9-10-x86_64/ and it seems like this worked:
cd Python-2.7.1CC="gcc -m32" LDFLAGS="-L/lib32 -L/usr/lib32 \ -Lpwd/lib32 -Wl,-rpath,/lib32 -Wl,-rpath,/usr/lib32" \ ./configure --prefix=/opt/pym32makesudo make install
But installing psyco didn't work:
- Download the lastest snapshot: http://psyco.sourceforge.net/download.html
- Extract it and go into the folder
- python setup.py install
This error appeared:
PROCESSOR = 'ivm'
running install
running build
running build_py
running build_ext
building 'psyco._psyco' extension
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -DALL_STATIC=1 -Ic/ivm -I/usr/include/python2.6 -c c/psyco.c -o build/temp.linux-x86_64-2.6/c/psyco.o
In file included from c/psyco.c:1:
c/psyco.h:9: fatal error: Python.h: Datei oder Verzeichnis nicht gefunden
compilation terminated.
error: command 'gcc' failed with exit status 1
Installing the package python-dev solved the problem, but I still could not use psyco. Now I've installed a 32Bit Ubuntu System.
