I'm installing Ubuntu 12.04 LTS on my Lenovo y500 with nvidia geforce 750M using uefi. What I've done so far
  1. Regular install with Ubuntu disc. (through legacy)
  2. Boot repair (recommended) (through legacy)
  3. Boot up in UEFI to OS selection screen
When I boot up I get the OS selection screen, but when I select the ubuntu choice, my screen is stuck on a purple screen.
Nothing responds, no F2, Ctrl+Atl+F1, Esc, nothing.
I've tried the following solutions, but have no luck:
  1. Updated Nvidia drivers: http://www.dedoimedo.com/computers/ubuntu-quetzal-nvidia.html That got me to the screen with the ubuntu logo and the dots, but soon after crashed into a black screen with commands. I can also no longer access login terminal via boot recovery
  2. Edited boot command: gfxmode nomodeset did nothing for me
  3. Tried to regular boot through recovery: Got to black screen with login terminal. Could login to access system, but still does not boot to regular ubuntu.
  4. Stuck on purple screen: Nothing changed.
  5. Tried nvidia answer: Unable to install Ubuntu on Lenovo Y500 With this, regular choice boots directly into login terminal, no gui or purple screen freeze.
    1. Tried sudo nvidia-xconfig. Did not visibly change anything.
Note:
  1. I am booting in UEFI
  2. I did disable srt
Derek
  • 151
[SOLUTION - Dual Boot Windows + Ubuntu]
  • I got my ubuntu working, but there are some things wrong with it.
  • First, because it's a Lenovo Y500, not all the drivers need will be automatically download or even be available so some things won't work (i.e. ethernet port, brightness adjust, unity?, etc).
  • Second, hibernate works half the time, still don't understand what causes it to work/fail. Suspend does not work for me at all (suspend works, but can't wake up correctly)
  • So if you are considering using Ubuntu, I would recommend against choosing the Lenovo Y500, at least for now.
  • Now the solution (starting from Windows only):
    1. Go to BIOS upon startup F2
    2. Go to the Security menu and turn off Secure Boot
    3. Go to the Boot menu and change boot mode to Legacy AND choose to boot UEFI first
    4. Save changes and restart
    5. After restart, select to boot (F12) into the Ubuntu system via USB or CD.
    6. Select Try Ubuntu (both times).
    7. Then install Ubuntu normally with the install program, but DON'T restart.
    8. After the installation, do Boot Repair: https://help.ubuntu.com/community/Boot-Repair and select the recommended option.
    9. After boot repair is finished you can restart and you should be able to get into Ubuntu and/or Windows
The KEY, I found after trying for two days, is to set Boot Mode to Legacy, BUT boot UEFI first and Legacy Second.
Hope this saved you guys from hours of pain.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
