I am using Evince document viewer as default in ubuntu 12.04.
How do I get a hyperlink to open when clicking on it?
You encountered a bug but there is a quick fix, I just did it and it worked, thanks to @maggotbrain by the way. He pointed me to this comment, and the suggested solution worked. So I was able to fix this issue with google chrome by doing the following:
  1. Open a terminal, type gksudo nautilus and hit enter,type your password and hit enter again, so now you are running nautilus with root privileges.
  2. On nautilus go to /etc/apparmor.d/abstractions/
  3. Open the ubuntu-helpers file and locate this lines inside:
    # Allow exec of libexec applications in /usr/lib*
    /usr/lib*/{,**/}* Pixr,
  4. You will insert this block of text after those lines:
    # From https://bugs.launchpad.net/ubuntu/+source/apparmor/+bug/964510/comments/12
    # While the chromium and chrome sandboxes are setuid root, they only link
    # in limited libraries so glibc's secure execution should be enough to not
    # require the santized_helper (ie, LD_PRELOAD will only use standard system
    # paths (man ld.so)).
    /usr/lib/chromium-browser/chromium-browser-sandbox PUxr,
    /opt/google/chrome/chrome-sandbox PUxr,
    /opt/google/chrome/google-chrome Pixr,
    /opt/google/chrome/chrome Pixr,
    /opt/google/chrome/lib*.so{,.*} m,
    but before this line:
    # Full access
  5. Save the file, close nautilus.
  6. Finally, type sudo apparmor_parser -T -W -r /etc/apparmor.d/usr.bin.evince on the terminal and hit enter, wait a few seconds until there is a line break and the cursor is awaiting for new input, this means the command went through with no problems :) hope it was helpful.
JorgeArtware
  • 3,637
  • Open the /usr/share/applications/mimeinfo.cache file.
  • Search for the lines containing x-scheme-handler/http= and x-scheme-handler/https=.
  • You should have either firefox.desktop or any other browser name followed by .desktop after the text in those lines.
  • For example the line may read:
x-scheme-handler/http=firefox.desktop;
x-scheme-handler/https=firefox.desktop;
green
  • 14,406
