10
How to know the pid of active (focused) window?
I want to write a script in which it is necessary to know whether the user is actively using a program [browsing internet with somthing say firefox] or doing something else [writing text with something say gedit]
In my case i want to download big files but don't want to hurt browsering speed. so when i browse the active window is of firefox and i want to stop downloading. When i read pdf active window is of pdf reader and i want to resume download. That's it.
totti
  • 6,908
  • 40
  • 48
7 Answers7
Finally I managed to work get the PID of actively focused window with xdotool
xprop -id `xdotool getwindowfocus` | grep '_NET_WM_PID' | grep -oE '[[:digit:]]*$'
totti
  • 6,908
  • 40
  • 48
Using xdotool's window stack:
xdotool getactivewindow getwindowpid
Bash:
#!/bin/bash
set -e
WINDOW_PID=$(xdotool getactivewindow getwindowpid)
xdpyinfo has, buried in its voluminous output, the window id of the window with the focus (see: Which window has the current focus?). With that, you can use xprop to get the the associated PID.
xprop -id `xdpyinfo | grep -Eo 'window 0x[^,]+' | cut -d" " -f2` | grep PID
Ternary
  • 4,187
bash
xdotool getwindowpid `xdotool getactivewindow`
fish
xdotool getwindowpid (xdotool getactivewindow)
crabvk
  • 111
The following works with Gnome 43:
  1. Install https://extensions.gnome.org/extension/4974/window-calls-extended/
  2. Run gdbus call --session --dest org.gnome.Shell --object-path /org/gnome/Shell/Extensions/WindowsExt --method org.gnome.Shell.Extensions.WindowsExt.FocusPID | sed -E "s/\\('(.*)',\\)/\\1/g" to get the PID of the focussed window or use a different method.
I know this is very old, but Google led me here, so in case someone is searching for a xprop-only answer:
xprop -id $(xprop -root '\t$0' _NET_ACTIVE_WINDOW | cut -f2) '\t$0' _NET_WM_PID | cut -f2
NOTE: '\t$0' makes xprop use TAB as the value separator, the default delimiter for cut.
-1
You can install wmctrl then use it to list all windows, wmctrl -l.
Henry Gibson
  • 839
  • 16
