What worked for me was to change the /etc/default/grub file as follows:
Open a terminal (Ctrl + Alt + T) and type sudo gedit /etc/default/grub
Find the line: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" and modify it to one of the following:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
or
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=Linux
acpi_backlight=vendor" (try this if the first one doesn't work)
Save and close gedit.
- Then type
sudo update-grub
- Reboot your pc.
EDIT
As from Ubuntu 13.10, this did not solve the problem for me on a Toshiba laptop. I needed one extra step for the problem to be solved.
I had to create an xorg.conf file in /etc/X11/ with the following contents:
Section "Device"
Identifier "Configured Video Device"
Driver "intel"
Option "Backlight" "intel_backlight"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Device "Configured Video Device"
EndSection
WARNING!! Getting the file wrong or if this configuration is not compatible with your hardware, might end up with an unbootable system! It happened to me.
In that case, you'll have to delete (or rename) the file, but to do so requires either booting from a liveUSB or liveDVD (the simplest way) or booting in recovery mode, making the Ubuntu partition rewritable and then delete the offending xorg.conf file.
EDIT2
Starting with kernel 4.4, the toshiba backlight device is blacklisted and doesn't appear any longer thus rendering these workarounds redundant.
