How do I get scanner working on 12.04? Looked at
Searching for printer/scanner canon pixma mp230 (32bit) ubuntu 12.04 drivers and how to install
downloaded scanner driver, run but nothing happened. Any help for dummies available?
found the scanner driver, it's working now http://support-au.canon.com.au/contents/AU/EN/0100469501.html
Only GIMP can start ScanGear. No other application software can start ScanGear. If GIMP is not installed, you must install the software.
hi all, found the 2 above line in the Scangear manual for linux. looks like only GIMP can open.
i tried and it really works after several round of installing and uninstalling different mp2** drivers.
sorry..what i meant is i installed scangearmp-common_2.00-1_i386 and scangearmp-mp230series_2.00-1_i386 then start the scanning successfully through GIMP. file -> create -> scangear MP
i tried before this on xsane and simplescan. both this doesn't work.
