I am using Ubuntu 12.10.
I downloaded from virtualbox.org the virtualbox package 4.2.4*.deb.
I wanted to install it with dpkg -i and terminal requested me to use command alien instead.
So I did alien <package> then dpkg -i <package> and used virtualbox.
Now I want to uninstall virtualbox (because something went wrong) because it was not installed with sudo apt-get install.
I want to use command dpkg -e <package> or dpkg --purge <package> but this ends with report
file or directory not found
Then
sudo dpkg -l | grep virtualbox
reports:
ii  virtualbox-4.2                                  4.2.4-81684~Ubuntu~quantal                     amd64        Oracle VM VirtualBox
rc  virtualbox-qt                                   4.1.18-dfsg-1ubuntu1.1                         amd64        x86 virtualization solution - Qt based user interface
what should I do next ?
dschinn1001
  • 3,863
Run this command in a terminal window:
sudo apt-get purge virtualbox-4.2 virtualbox-qt
That should remove them both.
Eric Carvalho
  • 55,453
MiJyn
  • 3,396
You can also use sudo apt-get purge virtualbox*, which should also remove both.
Eric Carvalho
  • 55,453
Try like this
sudo apt-get --remove purge virtualbox-4.2 virtualbox-qt
Beginner
  • 491
I also had run like this
sudo apt-get purge virtualbox-\*
But was not removing completely
To me following worked (Was trying this on Ubuntu 15.10 and Oracle Virtualbox 5.x)
which listed as below
# dpkg -l | grep virtualbox ii virtualbox-5.0:i386 5.0.12 104815~Ubuntu~wily i386 Oracle VM VirtualBox
Then i used the command
sudo apt-get purge virtualbox-5.0:i386
Basav
  • 111
