I have a hp pavilion dm3t with intel HD graphics running ubuntu 10.10 64 bit. I'm trying to compile and install a patched kernel according to this,
https://launchpad.net/~kamalmostafa/+archive/linux-kamal-mjgbacklight
So I downloaded the tarball from here (linked to from the page above): http://kernel.ubuntu.com/git?p=kamal/ubuntu-maverick.git;a=shortlog;h=refs/heads/mjg-backlight
I untar'd it to a directory, entered the directory and did:
make defconfig
I'm not sure if that's what I should have done but it was successful, so I did:
make
which seemed to work fine until it gave these errors:
ubuntu/ndiswrapper/iw_ndis.c:1966: error: unknown field ‘num_private’ specified in initializer
ubuntu/ndiswrapper/iw_ndis.c:1966: warning: initialization makes pointer from integer without a cast
ubuntu/ndiswrapper/iw_ndis.c:1967: error: unknown field ‘num_private_args’ specified in initializer
ubuntu/ndiswrapper/iw_ndis.c:1967: warning: excess elements in struct initializer
ubuntu/ndiswrapper/iw_ndis.c:1967: warning: (near initialization for ‘ndis_handler_def’)
ubuntu/ndiswrapper/iw_ndis.c:1970: error: unknown field ‘private’ specified in initializer
ubuntu/ndiswrapper/iw_ndis.c:1970: warning: initialization makes integer from pointer without a cast
ubuntu/ndiswrapper/iw_ndis.c:1970: error: initializer element is not computable at load time
ubuntu/ndiswrapper/iw_ndis.c:1970: error: (near initialization for ‘ndis_handler_def.num_standard’)
ubuntu/ndiswrapper/iw_ndis.c:1971: error: unknown field ‘private_args’ specified in initializer
ubuntu/ndiswrapper/iw_ndis.c:1971: warning: initialization from incompatible pointer type
make[2]: *** [ubuntu/ndiswrapper/iw_ndis.o] Error 1
make[1]: *** [ubuntu/ndiswrapper] Error 2
make: *** [ubuntu] Error 2
How can I compile and install this kernel successfully? I'm new to this and would appreciate any help.
