The file-name extension .webm is used for media files using the WebM multimedia format, which consists of the WebM container (a subset of the Matroska container) and audio and video streams with independet enconding and quality settings.
Description of the issue:
For files in the WebM format, the program file says that files are raw data, instead of determining and displaying the real file-format, which is WebM. Besides, Nautilus doesn't display the technical metadata of files in this format.
Why is the file program not displaying the file format for WebM files?
LiveWireBT
  • 29,597
Pili
  • 29
The short answer is: yes, it is supported. At least on Ubuntu 12.04, when I download a WebM video, I get
user@machine:~$ wget http://www.808.dk/pics/video/gizmo.webm
(...output truncated...)
Saving to: `gizmo.webm'
user@machine:~$ file gizmo.webm
gizmo.webm: WebM
user@machine:~$
It might be that your files are not correctly encoded and do not contain the magic numbers at the beginning of the file that allow to determine the file type. Maybe you could give us links to files that are not correctly identified by the file utility, or otherwise state how you created them.
EDIT: The Ubuntu version of the OP is 11.04 and apparently does not contain an up to date magic file recognizing WebM as a valid file format, possibly due to the fact that at time of 11.04 release the WebM was barely a year old. The magic file from 12.04 correctly recognizes the format.
January
  • 37,208
Just for your consideration: Parts of this answer comes from: Is there an application that will render the popular web video formats? which links to: Reduce avi size without losing too much quality
The FileInfo.com webpage related to "Video Formats" provides an extensive and really comprehensive list of video formats, its available software which can be used to play each one and the "popularity".
You may also wish to take a look to the "Digital Container format" and the table of "Comparison of container formats".
Based on that information, we find that:
[The Webm file format is a] Compressed video file created using the WebM format, an open, high-quality video standard; stores video compressed using VP8 technology and audio compressed using Ogg Vorbis compression; commonly used for delivering online videos using the HTML5 tag.
The WEBM container format is based on the Matroska container, which stores Matroska video in .MKV files. Most major Web browsers will support WebM as part of HTML5 video delivery. WebM is an alternative to the patented h.264 and MPEG4 standards, and is suitable for commercial and non-commercial applications.
NOTE: Google acquired ON2, the original developer of VP8 technology. VP8 is now an open and free technology.
Nevertheless, the information that seems to be lacking in such file format may be related to the metadata/tags, which is well known that the file format doesn't give any support for such elements, thus the information won't appear. See the table of "Comparison of container formats" for information related to "metadata/tags" in the proper column.
So, we can say that Ubuntu isn't giving such "deteriorating" image for a per-file-format related issue. Maybe the file format itself is giving a less complex set of information on its own, which isn't Ubuntu blame (nor any other OS).
Good luck!
If you want to extract info from multimedia formats like WebM, Matroska and others you have a variety of tools to choose from.
MediaInfo
MediaInfo is a project dedicated to providing a tool that displays the most relevant technical and tag meta data for video and audio files in a unified way for the plethora of formats out there. It is in the repositories as of 12.04 and can be installed via the mediainfo package.
Example output looks like this:
$ mediainfo big-buck-bunny_trailer.webm
General
Unique ID                                : 94077224337973666327274415816295077565 (0x46C69D45A185A9294D3D0A2F750056BD)
Complete name                            : big-buck-bunny_trailer.webm
Format                                   : WebM
Format version                           : Version 1
File size                                : 2.06 MiB
Duration                                 : 32s 480ms
Overall bit rate mode                    : Variable
Overall bit rate                         : 533 Kbps
Encoded date                             : UTC 2010-05-20 08:21:12
Writing application                      : Sorenson Squeeze
Writing library                          : http://sourceforge.net/projects/yamka
Video
Format                                   : VP8
Codec ID                                 : V_VP8
Bit rate                                 : 439 Kbps
Width                                    : 640 pixels
Height                                   : 360 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 25.000 fps
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 0.076
Stream size                              : 1.70 MiB (82%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : Vorbis
Format settings, Floor                   : 1
Codec ID                                 : A_VORBIS
Bit rate mode                            : Variable
Bit rate                                 : 64.0 Kbps
Channel(s)                               : 1 channel
Sampling rate                            : 44.1 KHz
Stream size                              : 254 KiB (12%)
Writing library                          : libVorbis (Everywhere) (20100325 (Everywhere))
Language                                 : English
Default                                  : Yes
Forced                                   : No
Exiftool
Exiftool from the libimage-exiftool-perl package knows a lot of formats, too. Additionally it can write meta data and provides a lot of information about the file similar to mediainfo. For more information see the exiftool manpage.
$ exiftool big-buck-bunny_trailer.webm
ExifTool Version Number         : 8.60
File Name                       : big-buck-bunny_trailer.webm
Directory                       : .
File Size                       : 2.1 MB
File Modification Date/Time     : 2012:09:17 20:46:02+02:00
File Permissions                : rw-rw-r--
File Type                       : WEBM
MIME Type                       : video/webm
EBML Version                    : 1
EBML Read Version               : 1
Doc Type                        : webm
Doc Type Version                : 1
Doc Type Read Version           : 1
Timecode Scale                  : 1 ms
Duration                        : 0:00:32
Date/Time Original              : 2010:05:20 08:21:12Z
Muxing App                      : http://sourceforge.net/projects/yamka
Writing App                     : Sorenson Squeeze
Video Frame Rate                : 25
Video Codec ID                  : V_VP8
Video Codec Name                : VP8
Image Width                     : 640
Image Height                    : 360
Track Number                    : 2
Track Type                      : Audio
Track Timecode Scale            : 1
Audio Codec ID                  : A_VORBIS
Audio Codec Name                : Vorbis
Audio Sample Rate               : 44100
Image Size                      : 640x360
Mkvtoolnix
Specific to Matroska formats, like WebM, you can use mkvmerge -i or mkvinfo from the mkvtoolnix package or other tools for manipulating and creating Matroska files.
$ mkvmerge -i big-buck-bunny_trailer.webm
File 'big-buck-bunny_trailer.webm': container: Matroska
Track ID 0: video (V_VP8)
Track ID 1: audio (A_VORBIS)
$ mkvinfo big-buck-bunny_trailer.webm
+ EBML head
|+ EBML version: 1
|+ EBML read version: 1
|+ EBML maximum ID length: 4
|+ EBML maximum size length: 8
|+ Doc type: webm
|+ (Unknown element: EBMLVoid; ID: 0xec size: 4)
|+ Doc type version: 1
|+ Doc type read version: 1
+ Segment, size 2165127
|+ Seek head (subentries will be skipped)
|+ Segment information
| + Segment UID: 0x46 0xc6 0x9d 0x45 0xa1 0x85 0xa9 0x29 0x4d 0x3d 0x0a 0x2f 0x75 0x00 0x56 0xbd
| + Timecode scale: 1000000
| + Duration: 32.480s (00:00:32.480)
| + Date: Thu May 20 08:21:12 2010 UTC
| + Muxing application: http://sourceforge.net/projects/yamka
| + Writing application: Sorenson Squeeze
|+ Segment tracks
| + A track
|  + Track number: 1 (track ID for mkvmerge & mkvextract: 0)
|  + Track UID: 3383112130
|  + Track type: video
|  + Default duration: 40.000ms (25.000 frames/fields per second for a video track)
|  + Timecode scale: 1
|  + Codec ID: V_VP8
|  + Codec name: VP8
|  + Video track
|   + Pixel width: 640
|   + Pixel height: 360
| + A track
|  + Track number: 2 (track ID for mkvmerge & mkvextract: 1)
|  + Track UID: 1552874170
|  + Track type: audio
|  + Timecode scale: 1
|  + Codec ID: A_VORBIS
|  + CodecPrivate, length 3097
|  + Codec name: Vorbis
|  + Audio track
|   + Sampling frequency: 44100
|+ Cues (subentries will be skipped)
|+ Cluster
Libav/FFmpeg
At last there is avprobe from the libav-tools package, by the Libav project who forked FFmpeg.
$ avprobe big-buck-bunny_trailer.webm
avprobe version 0.8.3-4:0.8.3-0ubuntu0.12.04.1, Copyright (c) 2007-2012 the Libav developers
  built on Jun 12 2012 16:52:09 with gcc 4.6.3
[matroska,webm @ 0x19119a0] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from 'big-buck-bunny_trailer.webm':
  Duration: 00:00:32.48, start: 0.000000, bitrate: N/A
    Stream #0.0(eng): Video: vp8, yuv420p, 640x360, PAR 1:1 DAR 16:9, 25 fps, 25 tbr, 1k tbn, 1k tbc (default)
    Stream #0.1(eng): Audio: vorbis, 44100 Hz, mono, s16 (default)
But I agree, it would be useful if file showed some information about the video. Please make a feature request in the appropriate channels (which are not on askubuntu).
LiveWireBT
  • 29,597
phoibos
  • 22,176
