12
I recently got a new Windows computer and would like to dual boot with Ubuntu. I don't really want to have 2 separate file systems (with mounting) but would like to integrate the two, if it is possible. Like for example I would like my /home/name/Pictures to have the same content as the Pictures folder in My Documents in windows, /home/name/Downloads to be the same as the Downloads folder in windows, Music to be the same as the window's Music folder, and even Desktop if possible. I understand some folders would have to be different, like AppData in windows would not be able to work properly so some duplicates might be necessary.
Is this at all possible? I hate how having Ubuntu feels like having a new computer all together and would like some unity (no pun intended).
Thanks.
Jorge Castro
  • 73,717
dukevin
  • 1,127
  • 19
Prerequisites
You have to have the Windows partition mounted in Ubuntu to make the following work .
Redirecting special folders
An equivalent of special folders (My Documents, My Music, My Pictures, etc) known from Windows folders was defined by the freedesktop.org project. The correspondig configuration file ~/.config/user-dirs.dirs is managed by the xdg-user-dirs-update command.
You could, for example, change the download directory by executing the following command in the terminal:
xdg-user-dirs-update --set DOWNLOAD /mnt/<WINDOWS_PARTITION>/users/<YOU>/Downloads
Another way to achieve the same is to manually replace $HOME/Downloads by /mnt/<WINDOWS_PARTITION>/users/<YOU>/Downloads in the configuration file (e.g. in gedit or nano).
To have the changes take effect run xdg-user-dirs-gtk-update afterwards and additionally xdg-user-dirs-update if you have edited the configuration file by hand.
Redirecting regular folders
You can also replace folders on your Ubuntu home folder with symbolic links to the folders on your Windows partition e.g.:
ln -s /mnt/<WINDOWS_PARTITION>/users/<YOU>/AppData/Roaming/Mozilla/Firefox/Profiles/<YOUR_PROFILE.default> ~/.mozilla/firefox/<YOUR_PROFILE.default>
That is a very simple solution and it does not work for everything, it might cause issues in some cases. However some people share settings for Firefox and Thunderbird that way.
Koen
  • 532
LiveWireBT
  • 29,597
Type this in terminal
gedit ~/.config/user-dirs.dirs
and link up to the absolute path of the windows folders. Then you can just "killall nautilus" or possibly reboot.
Yes, it is possible. I don't think it will display the same way since they use different icon sets. It should however display the same files and folders you may have placed on your desktop.
The problem you will likely run into with those is that windows references those files and folders from different relative starting points. (If you click them you'll get a "File not found" error.)
If, for some reason, you wish to continue, find your Ubuntu "Desktop" folder in your home folder. Rename it to something else like "desktop.bak" so you can undo this later. Open a terminal and enter 'ln -s /path_to/windows/Desktop Desktop'
Open your home folder and click on the new Desktop link. You should see the files and folders referenced on your Windows desktop. (For curiosity's sake, try clicking on them and see if any of them work.)
You should be able to log out and back in to see what you have on your desktop. If you find this isn't what you wanted, just delete the symlinked "Desktop" and rename the "desktop.bak" to "Desktop".
Argusvision
  • 1,721
Mount the Windows partition, then mount --bind its directories under your home. This makes your applications access the Windows partition transparently.
ignis
  • 4,247
