I run Ubuntu 24.04, I switched from Windows because i got pissed off at a multi billion dollar company that cannot make a proper update. Anyways, I have a TP Link, I tried every driver I could find on GitHub, but nothing worked, I reset the NetworkManager multiple times after every driver install. Still nothing. I found people with the same problem fixed it with one driver which I downloaded and I still have the same issue. The system recognizes the adapter but it doesn't seem to communicate with the router? If anyone could help I would be thankful. Kernel version is 6.8.0.
lsusb:
Bus 001 Device 002: ID 093a:2530 Pixart Imaging, Inc. Gaming Mouse
Bus 001 Device 003: ID 0d8c:0012 C-Media Electronics, Inc. USB Audio Device
Bus 001 Device 005: ID 03f0:f22a HP, Inc HP Laser MFP 135w
Bus 001 Device 006: ID 0e8d:2004 MediaTek Inc. CRT-LX1
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 258a:0049 BY Tech Gaming Keyboard
Bus 003 Device 003: ID 2357:0120 TP-Link Archer T2U PLUS [RTL8821AU]
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
EDIT: The issue was the .conf file for the driver was not configured good.
user68186
  • 37,461
sseki
Thanks for the help, I figured the .conf was bad in the driver, I changed some values and now it's working. .conf file (I left the comments since I am new to this, they are helpful):
# /etc/modprobe.d/8821au.conf
# Purpose: Allow easy access to specific driver options.
# Edit the following line to change, add or delete driver options:
options 8821au rtw_led_ctrl=1
# Note: The above `options` line is a good default for managed mode. Below
# are examples for AP mode. Modify as required after reading the documentation:
# Band 1 (2.4 GHz)
#options 8812au rtw_switch_usb_mode=2
# Band 2 (5 GHz)
#options 8812au rtw_switch_usb_mode=1 rtw_vht_enable=2 rtw_dfs_region_domain=1 rtw_country_code=US rtw_power_mgnt=0
# After editing is complete, save this file (if using nano: Ctrl + x, y, Enter)
# and reboot to activate the changes.
# Note: hostapd information is located at the end of this file.
# Documentation:
# Log options ( rtw_drv_log_level )
# 0 = NONE (default)
# 1 = ALWAYS
# 2 = ERROR
# 3 = WARNING
# 4 = INFO
# 5 = DEBUG
# 6 = MAX
# Note: You can save a log file that only includes RTW log entries by running
# the following in a terminal:
# sudo ./save-log.sh
# Note: A log option greater than 1 must be set. The name of the log
# file will be `rtw.log`.
# LED options ( rtw_led_ctrl )
# 0 = Always off
# 1 = Normal blink (default)
# 2 = Always on
# VHT options ( rtw_vht_enable )
#  0 = Disable
#  1 = Enable (default)
#  2 = Force auto enable (use only for 5 GHz AP mode)
# Notes:
# - A non-default setting can degrade performance greatly in managed mode.
# - Option 2 allows 80 MHz channel width for 5GHz AP mode, such as when
#   you are using hostapd.
# Power options ( rtw_power_mgnt )
# 0 = Disable power saving
# 1 = Power saving on, minPS (default)
# 2 = Power saving on, maxPS (not recommended for AP mode)
# DFS Options ( rtw_dfs_region_domain )
# 1 = FCC
# 2 = MKK
# 3 = ETSI
# Notes:
# - Activates DFS channels in AP mode.
# - DFS FCC 80 MHz channels for hostapd: 52(58), 100(106), 116(122) and 132(138)
# - For more information: https://en.wikipedia.org/wiki/List_of_WLAN_channels
# Note: An AP needs to listen on a DFS channel for a period of 60 seconds
# before transmitting on the channel. If any radar pulses are detected,
# the AP cannot use that channel and will have to try a different channel.
# Wireless Mode options ( rtw_wireless_mode )
# 1  = 2.4GHz 802.11b
# 2  = 2.4GHz 802.11g
# 3  = 2.4GHz 802.11b/g
# 4  = 5GHz 802.11a
# 8  = 2.4Hz 802.11n
# 11 = 2.4GHz 802.11b/g/n
# 16 = 5GHz 802.11n
# 20 = 5GHz 802.11a/n
# 64 = 5GHz 802.11ac
# 84 = 5GHz 802.11a/n/ac
# 95 = 2.4GHz 802.11b/g/n 5GHz 802.11a/n/ac (default)
# Country Code options ( rtw_country_code )
# Note: Allows the Country Code to be set in cases where it is unable to
# be obtained otherwise.
# URL: http://en.wikipedia.org/wiki/ISO_3166-1_alpha-2
# Example for the US: rtw_country_code=US
# Example for Panama: rtw_country_code=PA
# Example for Norway: rtw_country_code=NO
# Example for Kuwait: rtw_country_code=KW
# Example for Taiwan: rtw_country_code=TW
# To see all driver options that are available:
# $ ls /sys/module/8821au/parameters/
# To see the values that are in use:
# $ grep [[:alnum:]] /sys/module/8821au/parameters/*
# hostapd setup information for rtl8821au
# Note: The best settings can vary but the following may be a good place to start.
# options 8821au rtw_drv_log_level=0 rtw_led_ctrl=0 rtw_vht_enable=2 rtw_power_mgnt=1 rtw_dfs_region_domain=1
# Note: The best setting for `rtw_dfs_region_domain=` will depend on your location.
# /etc/hostapd/hostapd.conf
# hw ht capab: 0x962
# ht_capab=[HT40+][HT40-][SHORT-GI-20][SHORT-GI-40][RX-STBC1][MAX-AMSDU-7935]
# hw vht capab: 0x3c00122
# vht_capab=[MAX-MPDU-11454][SHORT-GI-80][RX-STBC-1][HTC-VHT][MAX-A-MPDU-LEN-EXP7]
sseki
