I'm using Ubuntu 10.04.4 LTS, and in my laptop there is a Broadcom BCM4312 WLAN card.
lspci output:
04:00.0 Network controller: Broadcom Corporation BCM4312 802.11b/g (rev 01)
    Subsystem: Broadcom Corporation Device 04b5
    Flags: bus master, fast devsel, latency 0, IRQ 18
    Memory at f4500000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: [40] Power Management version 3
    Capabilities: [58] Vendor Specific Information <?>
    Capabilities: [e8] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
    Capabilities: [d0] Express Endpoint, MSI 00
    Capabilities: [100] Advanced Error Reporting <?>
    Capabilities: [13c] Virtual Channel <?>
    Capabilities: [160] Device Serial Number 81-ac-1d-ff-ff-12-54-92
    Capabilities: [16c] Power Budgeting <?>
    Kernel driver in use: wl
    Kernel modules: wl, ssb
So as you can see, the current (and default) driver is wl - installed with Jockey.
But I have another Ubuntu based distribution on my laptop (BackTrack linux), which is also 10.04, but it has the b43 driver installed and the overall performance is much better. So I would like to install it on this OS too, but even google didn't help me.
So my question is how to install the latest b43 driver on my Ubuntu?
BuZZ-dEE
  • 14,533
Type in a terminal:
sudo apt-get install b43-fwcutter
Under the desktop menu System > Administration > Hardware/Additional Drivers, the b43 drivers can be activated for use.
Restart.
Edited:
Install dkms.deb, patch.deb, fakeroot, and bcmwli. Those packages are in Ubuntu installation CD in the following paths:
/pool/main/d/dkms.deb
/pool/main/p/patch.deb
/pool/main/f/fakeroot
/pool/restricted/b/bcmwli
Enable STA driver in additional driver.
sudo modprobe -r b43 ssb wl
sudo modprobe wl
jasmines
  • 11,311
