I understand that this is a totally novice question but...
What is the best way for me to transfer files between two PC's? I have a laptop with Ubuntu Desktop (12.04) and a local server I'm setting up using Ubuntu Server. I'm used to windows environment where I might typically browse the network via Windows explorer and move files around. This might work for Ubuntu desktop, but what's the best way for Ubuntu server?
Do I need to create a user on the server, then SSH into the server from the laptop? Can I then use a move command to move my files back and forth? What do I need to look into?
Thanks.
Anonymous
  • 127
5 Answers5
The easiest way is to use scp command :
As you use cp command `cp ~/file/ /mnt/file1
You can use scp : scp ~/file/ user@host:~/file1
Then it will prompt for credentials .
nux
  • 39,152
Video explanation
It's very simple in Ubuntu 16.04. You can just use the "connect to server" button in files (nautilus). In the popup window you need to type an sftp string like this:
sftp://username@hostname.local/
where username is the username of the other machine, and hostname is the hostname of the other machine. Then you'll be prompted for a password and you're good to go.
Note that you have to sudo apt install openssh-server on the remote machine.
842Mono
  • 10,070
Rsync is probably your best bet. It is an incremental file transmission protocol that allows you to keep folders in sync between machines, so it would be especially good for things like media.
phthano
Probably easier than that. If in the same local network, just right click on the folder you want to share and click sharing options. Then you get a menu which is self explanatory. That should work out of the box between two ubuntu machines.
Let me know!
leousa
  • 984
You can give giver a try
Giver Makes Transfer of Files Easier On A Linux Network By farshad on Feb 14 2011
Giver is a simple file sharing desktop application for Ubuntu Linux users. It automatically detects other users running Giver on a network and allows sending files and folders to them via simple drag and drop. There is no need to learn about complex network file sharing procedures. Anyone on the network can send files by dragging and dropping a file or folder next to the icon and name of a computer user visible on the main interface.
After Giver is installed, it shows you other computers on the network that have it installed as well, along with their computer name, IP and picture (provided the user has set one using Gravatar).
download giver
The first issue with Giver is a missing .so file that prevents it from working. This can be fixed by installing libx11-dev (11.10/11.04/12.04)
sudo apt-get install libx11-dev
For Ubuntu 11.10/12.04 besides the above issue, there's another issue that prevents Giver from working (it occurs for all applications that still use Mono runtime 2.0 instead of To fix this, run the command below:
sudo gedit /usr/share/applications/giver.desktop
And under "Exec", replace "giver" with the following:
/usr/bin/mono --runtime=v4.0 /usr/lib/giver/Giver.exe
Source:
blade19899
  • 26,994
