Our municipal library sends a *.acsm file by mail when we borrow a e-book, but I'm fed up with having to bother my wife to use her Windows account and we must reboot 'tween nix and doze. Adobe digital editions needs Wine and .Net35SP1. So Wine is installed, but the .Net35SP1 installer (dotnetfx35setup.exe) does not connect to download the needed files. Is the server down or is there another and easier way to install ADE? I've been trying all weekend.
Rooman
  • 29
Download ACSM files in Linux - without using Adobe Digital Editions!
There are a few limitations, but nothing too serious:
  • Only ePub is supported.
  • No PDF Command line only.
  • Alpha quality software. It works - but is a bit finickity
You can compile the code yourself, but I just downloaded the pre-built binaries.
On Ubuntu needed to sudo apt install libzip-dev
Once you've unzipped the download, cd into it and run:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$PWD
Then
./adept_activate -u youremail@example.com -p SuperStrongPassword
Use the same credentials as you do in Adobe Digital Editions. You can just use the -u flag and type your password in at the prompt - but I couldn't get that to work. The -p flag worked fine.
After a few seconds, you'll see:
youremail@example.com fully signed and device activated in /home/you/libgourou_utils_0.3.1/./.adept
Then run:
./acsmdownloader -f whatever.acsm
After a few moments, you'll see:
Created whatever.epub
That's it! Your file is downloaded and you can read the ePub.
Note: If you try to download a PDF, you'll get an error saying:
Exception code : 0x5007
Message : whatever.epub
You can rename the file back to .pdf, but it will still be encrypted.
source: Download ACSM files in Linux - without using Adobe Digital Editions!
Talaat Etman
  • 1,340
