I have installed Kubuntu. I am able to connect to Internet and able to access external sites, but in my local network I have bugzila installed that I am not able to access, even I am not able to ping the gateway also 192.168.1.1.
Below is the result of ifconfig command:
~# ifconfig
eth0      Link encap:Ethernet  HWaddr b8:70:f4:da:f9:a8
          inet addr:192.168.1.100  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:42 Base address:0x2000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:884 errors:0 dropped:0 overruns:0 frame:0
          TX packets:884 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:81131 (81.1 KB)  TX bytes:81131 (81.1 KB)
wlan0     Link encap:Ethernet  HWaddr 68:5d:43:2e:1c:79
          inet addr:192.168.1.26  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::6a5d:43ff:fe2e:1c79/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2446 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2324 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1909441 (1.9 MB)  TX bytes:393292 (393.2 KB)
How can I resolve this?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Roopesh
  • 49
Which interface is connected to the internet? "eth0" or "wlan0"? Did you add "gateway" IP to both interfaces? If so, remove gateway IP from the local interface.
You have two equal networks with address: 192.168.1.0/24 on two network interfaces: eth0 and wlan0. And it seems a gateway you are using configured toward the Internet but have no connection with your local network.
  • You need to configure your wi-fi router for different network address: 192.168.2.0/24 or something else.
  • Check your routes table by command: ip route
  • You could see similar record:
    default via 192.168.2.1 dev wlx8c882b131d84 proto dhcp metric 600
  • 192.168.1.0/24 local network with Bugzilla should be accessible from now because of there are no conflicting networks present anymore.
Gryu
  • 8,002
  • 37
  • 53
