For clarity, I have an Acer Aspire 5 A515-51G-5504
I installed 18.04 years ago and I've been using it ever since. I now use virtual machines for everything but when I started dabbling in linux back in 2018, I didn't understand how bad it was to install stuff on my host machine.
A couple years ago I had to install Wine to do some stuff for work and I'm kind of suspicious that it's malicious. I've tried to get rid of it but it refuses to die, like Tyrion Lannister. I've backed up everything I care about so now I'm 100% cool with nuking this whole thing and starting with a fresh installation of 18.04
My question is: should I change anything about BIOS or UEFI before I plug in my bootable flash drive and go through the installation process? I'm pretty sure I evidently did everything correct when I did this back in 2018 because everything has been fine. I changed my password in BIOS (which I do remember) and I'm pretty sure I enabled secure boot back then for UEFI. I just don't know if I should do this stuff again. Note: I do use this computer for work so I'm super nervous about screwing it up
This is what I get when I do lspci:
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #1 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Intel(R) 100 Series Chipset Family LPC Controller/eSPI Controller - 9D4E (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 3D controller: NVIDIA Corporation GP108M [GeForce MX150] (rev a1)
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411B PCI Express Card Reader (rev 01)
02:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
03:00.0 Network controller: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter (rev 31)
And this is what I get when I do sudo dmidecode -t bios -q
Vendor: Insyde Corp.
Version: V1.13
Release Date: 11/08/2017
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 8192 kB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Japanese floppy for NEC 9800 1.2 MB is supported (int 13h)
Japanese floppy for Toshiba 1.2 MB is supported (int 13h)
5.25"/360 kB floppy services are supported (int 13h)
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 1.13
Firmware Revision: 1.10
Please note that apparently, installing Ubuntu on Acer Aspires is notoriously difficult but somehow I managed to do it in 2018. If I should upgrade my BIOS, will that do something unexpected and negative? Part of me doesn't want to touch anything that isn't broken but I also do not want to compromise my security at all.
So am I good-to-go for doing a fresh install of 18.04 from here? Or am I about to screw this up? Thanks :)
