I am using Ubuntu 12.04 LTS on my Packard Bell EasyNote TS11HR-127GE laptop and I cannot adjust the brightness. If I change the slider, the brightness is always at maximum. My laptop is using NVIDIA Optimus and has a integrated Intel HD 3000 and a NVIDIA GT540M graphic card. I already installed the newest Bumblebee version but this has also no effect.
Anyone an idea?
Here is the output of lsmod:
Module                  Size  Used by
bbswitch               13396  0
parport_pc             32866  0
ppdev                  17113  0
bnep                   18281  2
rfcomm                 47604  0
bluetooth             180104  10 bnep,rfcomm
binfmt_misc            17540  1
snd_hda_codec_hdmi     32474  1
snd_hda_codec_realtek   223867  1
snd_hda_intel          33773  3
snd_hda_codec         127706  3 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel
snd_hwdep              13668  1 snd_hda_codec
snd_pcm                97188  3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
arc4                   12529  2
snd_seq_midi           13324  0
snd_rawmidi            30748  1 snd_seq_midi
snd_seq_midi_event     14899  1 snd_seq_midi
snd_seq                61896  2 snd_seq_midi,snd_seq_midi_event
ath9k                 132390  0
snd_timer              29990  2 snd_pcm,snd_seq
snd_seq_device         14540  3 snd_seq_midi,snd_rawmidi,snd_seq
mac80211              506816  1 ath9k
uvcvideo               72627  0
snd                    78855  16 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
videodev               98259  1 uvcvideo
soundcore              15091  1 snd
snd_page_alloc         18529  2 snd_hda_intel,snd_pcm
psmouse                87692  0
joydev                 17693  0
v4l2_compat_ioctl32    17128  1 videodev
serio_raw              13211  0
ath9k_common           14053  1 ath9k
ath9k_hw              411112  2 ath9k,ath9k_common
ath                    24067  3 ath9k,ath9k_common,ath9k_hw
cfg80211              205544  3 ath9k,mac80211,ath
i915                  468651  3
drm_kms_helper         46978  1 i915
drm                   242038  4 i915,drm_kms_helper
mei                    41616  0
i2c_algo_bit           13423  1 i915
mxm_wmi                12979  0
acer_wmi               28418  0
sparse_keymap          13890  1 acer_wmi
video                  19596  1 i915
wmi                    19256  2 mxm_wmi,acer_wmi
mac_hid                13253  0
lp                     17799  0
parport                46562  3 parport_pc,ppdev,lp
usbhid                 47199  0
hid                    99559  1 usbhid
tg3                   152032  0
sdhci_pci              18826  0
sdhci                  33205  1 sdhci_pci
Mokkapps
  • 181
Finally this worked for me.
gksudo gedit /etc/default/grub
Change the line:
GRUB_CMDLINE_LINUX=""
to
GRUB_CMDLINE_LINUX="acpi_osi=Linux"
Then run sudo update-grub and reboot.
(source)
Mokkapps
  • 181
Try adjusting the brightness with the button on you laptop, usually a Fx key. I am assuming you have tried to adjust with the software 'slider' but I'd try again after testing the hardware button.
If this does not work consider installing proprietary drivers.
Try this:
  1. Open a terminal (Ctrl+Alt+T).
  2. Then type sudo nano /etc/default/grub. It will ask for your password. Type it in.
  3. Around the 11th line, there will be something like:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
    Change it to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
  4. Save the file by Ctrl+O followed by Ctrl+X. Then run sudo update-grub in the terminal.
  5. Reboot and see if backlight adjustment works. If not, undo the changes you did above, by invoking the text editor as in steps 1 and 2.
Hope it helps. Credit to this answer.
Same solution as one-liner
For this solution no nano knowledge is required. It is also handy for multi-machine installation scripts. This was tested on a Packard Bell Easynote TE11HC with Intel graphics.
sudo sed -i 's|^GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"|GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=Linux"|' /etc/default/grub && sudo update-grub
Serge Stroobandt
  • 5,719
  • 54
  • 59
