I'd like to know the shortcut that lets you open a terminal window in a specific directory just like when you press the left button on it and you click on 'Open in terminal' in the pop-up menu.
Thanks in advance !!
DBG
The shortest way in a default installation is Ctrl+F10 E. There is no single shortcut key to directly open a terminal.
Caveat In Ubuntu 22.04 (Files 42.2) this is broken. Ctrl+F10 E now opens the folder menu of the bar (⁞) instead of the right-click context menu. That behavior also breaks the use of the Python extension described below to a large extent. Still, assigning a nautilus specific shortcut using the extension works.
A good way to implement a direct shortcut key is to replace the default extension by a nautilus python extension, nautilus-open-any-terminal. Next to allowing for a single shortcut key, it allows you to substitute a terminal of your choice, if you wish.
  1. Quit nautilus fully
    nautilus -q
  2. Make sure python3-nautilus is installed: sudo apt install python3-nautilus
  3. Install the extension, either using pip as indicated on the website, or by grabbing the source code and placing it in a text file ~/.local/share/nautilus-python/extensions/open_any_terminal_extension.py.
  4. Enable the dconf settings
    glib-compile-schemas ~/.local/share/glib-2.0/schemas/
  5. Define the settings:
gsettings set com.github.stunkymonkey.nautilus-open-any-terminal terminal gnome-terminal
Supply gnome-terminal or any other of the terminals listed in the source code.
gsettings set com.github.stunkymonkey.nautilus-open-any-terminal keybindings '<Ctrl><Alt>t'
to set the Nautilus keybinding for opening the terminal.
gsettings set com.github.stunkymonkey.nautilus-open-any-terminal new-tab true
if you want to open the current directory in a new tab in a running instance. Otherwise, it will be a new window.
Bonus tips:
  • Remove the now superfluous default extension: sudo apt remove nautilus-extension-gnome-terminal.
  • Enable hotkeys in the right-click menu by editing the source code of the extension: where the menu label is defined, add an underscore before the letter you want to activate as a hotkey for the function, as in
    label=_(u"Op_en {} Here").format(terminal.title()),
With this example, also Ctrl+F10 E will work to open a terminal here.
vanadium
  • 97,564
I have recently moved to Ubuntu 22.04.2 LTS and had the exact issue of not being able to open the terminal on the current directory. For example, in windows I could use alt+d and then write cmd, and the terminal would open in the current directory.
This is the closest I could get to open terminal in the current working directory using just the keyboard (it has a bit more keystroke but might be useful also)
When we are in a folder and want to open the terminal at the same place, then the following keystroke brings the terminal up in the current directory
shift+f10 then two up arrow keystroke and enter
I have to say I came across this by accident while pressing some keys on my keyboard.
I hope it helps :)
UPDATE I: I just noticed one limitation of this approach while using the above-mentioned approach. If I am already selecting one file/folder, then shift+f10 does not open the floating window that has Open in Terminal option, but it opens another floating window that is specifically related to the file/folder I have selected.
UPDATE II: Found a more convinent way shift+f10 + e. This works like a charm (given the limitation mentioned in UPDATE I sadly)
Zubaer
To open the current directory in terminal from File explorer use shift+F10+e
Ashu
